Sponsored by:
Sponsored by: CARiD
2000 26hp Yanmar Tractor Pump ?
Old Oct 18, 2007 | 08:37 AM
CTD03's Avatar
i have a 2000 JD compact 4200 hydro
i want a little more hp out of it.
does any body have one?
i would like to turn up the fuel pump to get a little more hp not much but it always bogs when i move dirt or mow heavy with it
i might also add a turbo but thats later on down the line
how much hp can the hydro handle befor it no good
so really all i want to do is turn the fuel up a couple of turns
is there any web sites i could go to?
thanks i am hoping yall will help me
thanks
CTD03
Old Oct 18, 2007 | 09:52 PM
sixb's Avatar
My little BX1800 4x4 18 hp kubota never bogs when moving hay, dirt, gravel, snow, tilling, or manure. But i would also like a little more power & some whistle, so if you figure it out let me know.
Old Oct 18, 2007 | 10:27 PM
dieselfuelonly's Avatar
DTR question asker
Make a post on www.tractorbynet.com in the Yanmar section... they should help you, great group of guys over there, sure helped me with my YM1401D .
Old Oct 19, 2007 | 04:10 AM
CTD03's Avatar
THANKS i am going to go look around on that site to see what they have
Old Oct 19, 2007 | 06:12 AM
G1625S's Avatar
Just about everything 'Yanmar' in a John Deere is JD spec Yanmar stuff, so it won't be like any Yanmar tractor. You'll be better off posting in the JD section, although those guys seem to just go buy a bigger tractor when they run out of power Having said that, Tractorbynet is a great site with a bunch of great folks and tons of info. Have fun looking around
Old Oct 19, 2007 | 12:17 PM
CTD03's Avatar
thanks for the info i am going to print it and see what i can do this weekend
Old Nov 5, 2007 | 04:41 PM
CTD03's Avatar
Originally Posted by jdreckard
I have a JD 4300. I turned up the fuel on it and it definately helped. These newer tractors are turned down so far from the factory that even under max load they produce little if any smoke. My rule of thumb for tractors is that when reved up from idle under no load they should send out a light haze. Then under load they will smoke about right. The max fuel screw is located on the back side of the fuel pump under the shutoff solenoid. It has a round cover with safety seal wire. You need to loosen the lock nut and turn the entire threaded shaft. I think you turn it infor more smoke.
On the topic of turbos, JD now has the turbos on the small engines like ours from the factory. Therefore you could purchase this from JD and install it on your tractort. Be aware though that the turbocharged models have a larger oil pan with much greater capacity (6-8qts).
Hope this helps
Randy
the max fuel screw was on the back of the pump but this was up near the top i loosened the nut and and turned it. any ways i was wondering if its smoking at fuel throttle then its really going to smoke under load?
heck i was mowing some thick grass this weekend and it was nothing but black smoke pooring out of my tractor.
i was wondering if i turned it the wrong way or the right way i can get it to smoke when i throttle up and then kick the mower on. any ways how much does your tractor smoke i can lay a black cloud when i get in to mowing the thick grass.
Should i keep adjusting the thread shaft intill the tractor hazes at full throttle? i am just worried its going to smoke like crazy under load
G1625S
Jul 27, 2012 06:25 AM
DieselDaze
Oct 3, 2006 09:15 PM
DieselDaze
Sep 15, 2006 03:10 PM
Dodgecaveman
Jun 22, 2005 12:11 PM
DieselDaze
Dec 22, 2004 04:54 PM
