Sponsored by:
Sponsored by: CARiD
1984 Ford F-350 Fuel economy help!
Old Oct 18, 2010 | 06:25 PM
sled4fun's Avatar
Have a coworker with the 6.9L diesel in it. He is only getting 10-12 mpg. Is there anything short of buying another truck that can net him some mpg gains. He rebuilt the engine a fuel years ago and has put a new injector pump on it. Is the exhaust, intake, fuel system, cam the biggest weak spot on this year engine. I ask because I have heard many people with excursions that use the 7.3L engine. They get closer top 20.
Old Oct 18, 2010 | 08:29 PM
PoorMansCat's Avatar
If I remember correctly, the 6.9l is an N/A engine..(no turbo)
The 7.3l in the Excursions was a TA HUEI.
My F.I.L. has an early 90's 7.3L N/A engine in his 1-ton crewcab dually. Old truck will probably run forever, just won't get there very fast!.
Never tried to check the fuel mileage on it, due to the stupid flowback lines always leaking..
Old Oct 18, 2010 | 10:57 PM
RAMRODD's Avatar
The old 6.9 diesel is a tuff dinosaur with no weak spots as far as I am concerned. Back when the speedo worked on my 85 F-250 10-12 was normal highway milage I have 4.10's with a 4 speed. 55 mph would get you 17-18
Old Oct 18, 2010 | 11:18 PM
Lil Dog's Avatar
I would have the injection timing checked and check the fuel pressure from the lift pump. Other than that, not much can be done unless you want to go through the injectors.
Old Oct 19, 2010 | 09:28 AM
sled4fun's Avatar
The truck has a manual trans and non-turbo. I just thought mid teens would be reachable as a daily highway driver with minor tweaks.
Old Oct 20, 2010 | 03:09 PM
gorms's Avatar
Indirect injection is not very efficient, and I've heard the typical life expectancy of an injector on a IDI is 100K miles if you're lucky. This has proven true with all the old trucks at work, Chevy 6.2-6.5 and Ford 6.9's.
Old Oct 29, 2010 | 09:21 PM
mariner's Avatar
The info you have been given re 6.9 IDI is correct.
I have a 1986 F-250 (bought it new) with auto (C6) tansmission and 3.55 rear end. On a long run with a 21ft travel trailer or truck camper and 60mph max., I could approach 18 mpg (imperial gallon) - but my engine has an after market turbo on it. I put the turbo on at around 80,000km and now have 350,000km and the engine still doesn't burn oil leaks a bit now and then.
The bigger exhaust helps as does a modified air supply to increase volume. Fuel pump timing helps of course and if the timing was out, you would really notice a difference in power after the adjustment.
Good engine and a real workhorse. If you could get a used turbo cheap, that would help a lot.
mariner
Old Oct 30, 2010 | 11:54 PM
whereswaldo250's Avatar
Meet a guy with a 6.9, he was the original owner (1986) and he was getting 20mpg with 457000 on it.
Old Oct 31, 2010 | 11:09 AM
6cylinders's Avatar
No overdrive, how fast is he going on the highway? What rearend ratio?
I had a 6.9 for many years, if you try to run 70-75 the MPG's suffer big time.
DieselDaze
Mar 19, 2013 04:11 PM
SjLingenfelter
Jun 20, 2008 10:31 AM
jaconst
Mar 30, 2006 06:06 AM
BIGBADBOB
Jun 10, 2005 11:41 AM
MADSEN
Apr 9, 2004 03:21 PM
