Sponsored by:
Sponsored by: CARiD
02 dmax ?
Old Nov 7, 2006 | 05:11 PM
TUGUM's Avatar
02 dmax ?
anyone know what might be causing a 02 dmax
to smoke kinda a grey tint at idle or just above after its warmed up
BTW it has a banks 6 gun and about 200K on the clock it was scaned and
found a #6 misfire and you can feel a slight miss just above idle other than
that the truck runs pretty strong,I'm thinking injector or orings.the oil does smell alittle like diesel.thanks in advance for your help
Old Nov 7, 2006 | 07:37 PM
Hdmax's Avatar
If it is a whitish gray, it may be the injectors.
Old Nov 7, 2006 | 09:08 PM
TUGUM's Avatar
not sure just goin by what he told me on the phone,i'll try to see it in the next day or 2
Old Nov 8, 2006 | 09:02 AM
Lil Dog's Avatar
Its the injectors... What about 80,000 miles on the truck???
GM will first try to reflash the ECM, then change the fuel filter, then air filter then spend 1 hour on the computer and finally take your truck for 3 days to change the injectors, if they are in stock.
Luckily this will be on warranty for you.
Old Nov 8, 2006 | 03:47 PM
TORQUE's Avatar
These engines especially are prone to injector failures , and are quite costly to replace if you're paying the bill. At least one injector is bad, hopefully it didn't stay that way for too long. With fuel in the oil it means it was also washing away oil film for lubrication from cylinder/s.
If it is still in warranty, get it there fast and hopefully they will cover it, don't forget to remove all traces of performance mods. Hopefully they will replace all injectors, but I wouldn't count on it, usually just the bad one. This means you will be having this done again soon for the others to be replaced once they crater . Are you buying it, or is it someone you know?
Old Nov 8, 2006 | 07:10 PM
XLR8R's Avatar
That isn't FredW's truck is it?
Old Nov 8, 2006 | 07:17 PM
TORQUE's Avatar
You said what I was thinking, but didn't say.
Old Nov 8, 2006 | 08:30 PM
TUGUM's Avatar
no just a friend of a friends i tried to tell him to remove at least the box
he says he'll try to get it covered anyways " to cheap to pay to have it taken off" .He's outa state or i would of done it.thanks for the info
Old Nov 9, 2006 | 12:15 PM
Lil Dog's Avatar
If he doesn't cover his tracks.. The parts and labour for his injectors will be around $5000 at a minumum(thats only $800 per injector, they are more than that over the counter)....
His choice..
Old Nov 9, 2006 | 09:20 PM
XLR8R's Avatar
Where's FredW when you need him?
He knows exactly how much it costs....
1sttruck
Oct 20, 2003 05:33 AM
SjLingenfelter
Oct 2, 2003 09:28 PM
James Lucas
Jul 25, 2003 11:24 AM
TPilaske
28
Jul 16, 2003 09:53 AM
DieselDaze
May 20, 2003 07:38 PM
