Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
acetone vrs methonal
Old 12-07-2014, 02:24 PM
Joe Cannon's Avatar
I was not sure where to post this one so here it goes...I have a methonal injectoin kit on my truck. I mostly use winter windshild fluid as methonal is hard to find.
However Acetone is easy to find
After doing a bit of reseach, it seems acetone in the fuel has many benifits but have no idea how a say 30% acetone water mix would do instead of meth at the same %
Ideas????
Old 12-07-2014, 02:40 PM
Administrator/Jarhead
madhat's Avatar
Just use heet gas line dryer... it's ~99% methanol.
http://www.walmart.com/ip/HEET-Gasli...mover/16408667
Old 12-07-2014, 02:52 PM
Joe Cannon's Avatar
heet =$$ in the amounts that I use looking for something a bit cheaper...
Old 12-07-2014, 04:53 PM
patdaly's Avatar
Does Acetone mix with water?
Old 12-07-2014, 07:43 PM
madhat's Avatar
Are you running this all the time as a power adder?
Old 12-07-2014, 07:57 PM
madhat's Avatar
I just did a little brief reading, it looks like acetone will burn much different than methanol... it may be to flammable, like injecting gasoline... it was just a brief read, I didn't go into heavy research.
Old 12-08-2014, 08:09 AM
patdaly's Avatar
I guess I am also confused, I did a quick Google search and there seems to be plenty of suppliers off racing Methanol in SC.
OP, where are you located at in SC?
Old 12-10-2014, 05:13 PM
Joe Cannon's Avatar
I am in Summerville SC.
And yes it mixes with water very well..We get it in tote tanks at work and I use it everyday there as a solvent.
I know its great to remove water from gasoline.
It also breaks up the surface tension of water and some other liquids. It is really close in it's propertys to alchol (it can be made from it by adding a Bacteria of all things..)
I guess i need to look at the flash point of each etc...
Old 12-10-2014, 05:48 PM
madhat's Avatar
Methanol 52 to 54 °F
Acetone −4 °F
Old 12-10-2014, 06:43 PM
Rons red Ram's Avatar
Methanol has a pretty stable burn. Acetone wouldn't be too friendly to many seal materials. Thinned down or not, I'd be real skeptical about putting it into an engine that isn't cheap to rebuild or replace.
kyle_truck_pull
13
05-13-2009 12:55 AM
sawboywv1
12-24-2003 01:32 PM
Mopar_Mudder
16
06-28-2003 12:50 PM
Mopar_Mudder
30
02-17-2003 04:18 PM
Mopar_Mudder
11-05-2002 10:40 PM
Quick Reply: acetone vrs methonal
