Black diesel
From: Lingleville TX but active duty Air Force all over the world currently
Originally Posted by infidel
zack, since you have a 12 valve you better be careful, someday you might be pouring a chewed up KDP into your tank.
Sure the filter cleans up the oil but the sludge ends up in the bottom of the pan. Think it would be a good idea just to at least run it though a screen in order to get longer life out of your fuel filter.
The KDP is permanently fixxed now.........
So, what else should i worry about from runnin oil.......
I do value you opinoin Infidel since you are usually one of the first to answer my questions on here...
Zack, I was kidding about the KDP, you'll have no problem running used oil in your 12 valve.
Personally I would pour the oil though a paint strainer just to increase the life of your fuel filter.
INFIDEL, I WAS NOT OFFENDED IN ANY WAY......THE KDP IS A TOUCHY SUBJECT AFTER WHAT THE DEALER DID......
WHERE DO I PICK UP A PAINT STRAINER AND HOW MUCH DO THEY COST.....
I WAS WONDERING ABOUT THE ROPE AND 2 BUCKETS TRICK.....HOW DOES THE OIL GET FROM ONE BUCKET TO THE OTHER THOUGH?
THANKS IN ADVANCE,
ZACK
THANKS IN ADVANCE,
ZACK
It works by weeping from one to the other... kinda like a siphon... but you are going to be there a long time... it is slow and messy.
I would think of this as a last resort or science experiment.
Oilguy
Oilguy
Originally Posted by Marine
Probably the best thing would be a 2 stage filtering system. First run with a course filter, second one with a fine filter.
This post came at the perfect time for me, as I have been tripping over 60-80 gal. of waste oil that has on an average of 1 hour of dyno time on it. Gadz....I can bump up my mileage and clear this stuff out at the same time.
My questions are these: Any problem burning Mobil 1 10W30 full synthetic oil, and how rich do I dare mix it. I have read 5%(Cummins) to 25%. I will probably start at the 5% mix and maybe work my way up to something like 10%. If the oil gives off the same BTUs, I could effectively end up pulling something well over 20mpg from my 600CTD.......YAHOOO!!
Mike
ZACK
I've tried cleaning the solvent in my parts washer tank by running it though nylons, they clogged up real fast.
Then again solvent can get real dirty.
My local Ace Hardware has them in the paint dept in three different mesh sizes, less than a buck each.
Here's another question to throw in the mix...everyone assumes all oils are petroleum based. What about parrafin based oils? Will it burn the same as petroleum? better? worse? clog fuel filters? Just a thought for a new discussion
Originally Posted by Kuntry
So how does sythetic oil play in to this equation?
Now, I am hoping to hear from someone smarter than me that my 70+ gal. of synthetic oil will indeed be suitable for mixing in with the #2 in my tank. Again, I look to start at a 5% blend, and hopefully being able to working up to around 10%.
Comments please. Thanks.
So how does synthetic oil play in to this equation?
This indicates to me that synthetic doesn't burn well and that you don't really get much fuel value out of it.
I give the considerable amount of waste oil I generate to a friend who heats his shop with it. He'll take AFT, gear oil, hydraulic fluid and motor oil but asks that I leave the synthetics out. Says they clog up his heater nozzles.
People I know who have tried burning synthetic say that with more than a couple quarts per tank that their trucks smoke a lot.
Thank you for the quick reply to the question posed on burning synthetics. DANGIT! Was just about to pour in my first filtered jug of the stuff. As cheap as I am, and as excited as I was about getting rid of the stuff, I sure don't want to do anything to mess up my sweet truck. Guess I will sort thru the jugs and find the Rotella that came out of said truck at the last change. To repeat myself......DANGIT!
