Started 6bt crewcab project - Pics on blog.
Old Apr 6, 2008 | 11:54 PM
  #46
Alwaysworking's Avatar
alwaysonDTR
will that give you, your drive lines for the crew.
Old Apr 8, 2008 | 12:04 AM
  #47
Trooperthorn's Avatar
Just the front. I'll just have six states mod one of my extras. Don't know why or when you need to go with a two piece. There is only about 5 feet from my t-case to my diff. I could retube the one off my '92 donor.
Old Apr 8, 2008 | 12:08 AM
  #48
alwaysonDTR
we can make them too if you want? and can be balanced with out weights.
but i would have thought the wheel base would have been the same from a long box x-cab and a crew short box but i don't know.
Old Apr 8, 2008 | 01:36 AM
  #49
Bogie's Avatar
Crew Cab Short Bed is 149" WB I can't tell you a LB till I get in the garage and look in the factory service man.
Old Apr 9, 2008 | 12:40 AM
  #50
You are right about the wheel base, but my donor driveline is out of a standard cab. Also, the donor was an auto, and the crew is the nv 4500 which I think is shorter. I havn't measured it yet.
Old Apr 9, 2008 | 12:07 PM
  #51
Trebor's Avatar
I think that 149" is also the same as a Club Cab with an 8' bed.
Old Apr 15, 2008 | 12:31 AM
  #52
alwaysonDTR
whats the new donor looking like? and whens the ram charger convertion starting? that will be cool to see driving around.
Old Apr 17, 2008 | 11:51 PM
  #53
The 5-spd truck came with a bonus. 25 gallons of good ole' number 2, diesel that is.
Other than siphon out the gold, all I have done is cut 18 inches off the frame rails so I can park it closer to the shop and get it out of the way.
I have had little time to do anything for a couple of weeks. Work and school and family.
I hope to get on the rc as soon. If I just stuff it in and don't get fancy. It should go fast. My debate right now is on springs. Clearly the schoolgirl springs on the fron of the ram-c will not suffice. Do I use my 5 inch lift set off the crew? Put stock 3/4 ton ctd in there? Buy a set? I'm worried about this shorty truck riding like a pogo stick.
Old Apr 18, 2008 | 12:04 AM
  #54
alwaysonDTR
what about adding some leaves to the stockers?
Old Apr 19, 2008 | 11:54 PM
  #55
Yeah, I have a lot of options. I can't decide how tallto make the rc. I know softer springs will make for a better ride and articulation, but I realy don't want to dink with this one. I just want to get it working then get back to the crewcab. Will probably put on a stock set of 3/4 tons up front and throw it all together. Let the good stuff be a future progect.
Old Apr 20, 2008 | 12:00 AM
  #56
alwaysonDTR
that will be the easiest, you should have the rc done by tomarrow right?
if you want articulation put rears on the front, i have a freind that did't on a blazer with cross over steering and a lift, it was really cool, that thing can flex.
Old Apr 20, 2008 | 09:54 PM
  #57
Fred Swanson's Avatar
you should be able to start with stock diesel springs up front and the RC's for the rear.
Old May 11, 2008 | 12:57 AM
  #58
Finally worked on the crew again. Fixed the cab mounts and painted the frame. Check out the blogsite.
http://crewcabcummins.blogspot.com
Old May 11, 2008 | 01:02 AM
  #59
alwaysonDTR
cool i was woundering
Old May 11, 2008 | 01:11 AM
  #60
I wonder why rears on the front would flex more?
