Ford Excursion cummins swap (HPCR & 48RE)
Old Mar 20, 2008 | 01:30 PM
  #361
5.9Excursion's Avatar
PM sent...
should explain it for ya.
Old Mar 22, 2008 | 11:11 PM
  #362
GlennRMK's Avatar
Just read through this whole thread
5.9Excursion, you are one hell of a mechanic! The electrical engineer part doesn't hurt either!
Very impressive work!
I have a buddy that is putting an 03 CommonRail engine in a 79 Bronco and I will have tell him to read up on this thread. A ton of good info!
I will be interested to see what you think when get your rail pressure issues figured out.
Did you get the stock tach to work?
Again, my hats off to you!
Old Mar 23, 2008 | 12:37 AM
  #363
Thanks...
It was alot of research ahead of time as I couldn't find anything documented on all the details of a swap like this. That's one reason why I decided to put it all together, hopefully it will provide enough info for others to tackle a challenge like this.
Yes the stock tach is working now.
Currently waiting on a modded FCA, and hopefully Don M will get moved into his new shop soon so I can get some Flux 1.8's installed in this thing.
Old Mar 30, 2008 | 09:39 PM
  #364
94ttss's Avatar
Just came across this thread. Great job on your conversion .
Awesome write up.
Here is a pic of mine, I've got about 20k miles on it so far and have been enjoying it for a little over a year.
Old Apr 7, 2008 | 08:40 AM
  #365
Aggie007's Avatar
Did you have to wire up the vistronic fan drive. There are five wires. On the fan side there is a black, red, white, orange, green, do you know which one is which. One is for park lockout solenoid control, sensor ground, fan speed sensor, 5 volt supply, and fused ignition switch output (run).
Old Apr 8, 2008 | 07:04 AM
  #366
Yes I did, I'll have to see if I can find where I wrote it down. I know that the service manual didn't cover it...
Old Apr 16, 2008 | 03:52 PM
  #367
dieselclam's Avatar
I need that info too...
Thanks-
Old Apr 16, 2008 | 04:56 PM
  #368
Well I need it as well now
I've been chasing a squeaking noise for quite some time. Replaced the belt tensioner, power steering pump, and idler pulley bearing. Still squeaks... My used fan clutch has always had a very very slight wobble to it. Somehow the fan caught the fan clutch wiring and ripped it out. Luckily nothing else was damaged. But it lost my connector so I can't tell which wires went where. So I also need to find where I wrote that info down.
I also need to find a fan clutch (local dealership wants $380 for it)
Currently, I just cut the rest of the wires off and have been running it like that for now.
Still having issues with my FCA and still waiting for a replacement...
Time is hard to come by, working 12 hour days currently. Pulled my engine and tranny out of my 01 last night. Runnin' on 3 hours sleep, thank god for caffeine
Old Apr 16, 2008 | 09:46 PM
  #369
julio's Avatar
Julio from Miami
Im doing a cummins conversion on a 01 Ford Excursion that originally had a 7.3 I'm almost done I am wondering if anyone of you know which fan blades can I use or do I have to use electric fans? Thanks for the help I'll be putting pictures up soon.
Old Apr 16, 2008 | 09:52 PM
  #370
AlanB's Avatar
What Cummins motor are you using? If it's a common rail use the cummins fan and clutch.
Old Apr 17, 2008 | 08:43 PM
  #371
julio's Avatar
Thanks for the reply. I,m using a common rail ,but I put the cummins fan and clutch but it hits my water reservoir tank.
Old Apr 17, 2008 | 10:03 PM
  #372
AlanB's Avatar
Look at Kai's truck a few posts up, he built a sweet aluminum reservoir.
Old Apr 20, 2008 | 05:10 PM
  #373
julio's Avatar
Thans for the help!I got one more question :I'm using a 48re transmission,would it work ok or would I have to use a control box ?
Old Apr 20, 2008 | 09:31 PM
  #374
ramman's Avatar
If it's an 04.5 or newer engine and transmission the Cummins ECM controls the tranny .
Old Apr 21, 2008 | 06:13 PM
  #375
julio's Avatar
Thanks for the help,I'll be getting my wiring tomorrow,so I'll let you know how it runs later.
