46 dodge
Old Mar 24, 2008 | 02:48 AM
devilsriverlamb's Avatar
46 dodge
I have a 1946 Dodge 1 1/2 ton(year before dubbed the name powerwagon)and am wanting to put a cummins in it. I feel that the easy way to do it is to just buy a 4BT. Is there any major "downside" to the 3.9 over the 5.9.
P.S. Does anyone know where to locate a 4BT????
Old Mar 24, 2008 | 02:55 AM
Alwaysworking's Avatar
alwaysonDTR
i think the 6's are easier to get and cheaper to accuire than 4's because there are so many pick ups around with them.
Old Mar 24, 2008 | 08:23 AM
sixb's Avatar
That is exactly right on, atleast in my case out here in UT. None of them are cheap, but the 5.9 and it's parts are way more available. I have only seen two 4bts in our local classifieds, one was an industrial application for 2g and the other I think was also ind. for 3g. My donor truck was 1700.00 and that was a 92 5.9 auto 2wd which would get you off to a low cost build since yours is a 2wd. There are bread trucks out there that would be good for you also, but in UT they are far and few between. Dovebid.com is a good place to look for the bread trucks, the only problem I have is that they are never close and you can't go for a test drive.
Old Mar 24, 2008 | 08:38 AM
It is a 4x4. I dont know if that makes a difference
Old Mar 24, 2008 | 10:08 AM
74dart's Avatar
I've seen both in the military version of the power wagon and used to have pictures and the 6 has a hard time fitting without modifing the cab where as the 4 fits fine. There was one that had a 4bt and warn hubs on the front allowing 2wd and would get the in the high 20s on the highway.
Old Mar 24, 2008 | 12:11 PM
alwaysonDTR
if its a 4x4 then it would be easier to get a 4x4 dodge pu with the 6 and what ever type of trans you want manual or auto, then just put drive line to fit it, unless you really don't want to modify the firewall, and i would think that the 6 could get better mpgs in a heaver rig than the 4 could
Old Mar 24, 2008 | 01:28 PM
coorsman87's Avatar
you make a very good point. I am seriously considering this option, but i kind would like to keep the LONG frame and the 20" wheels
Old Mar 24, 2008 | 01:30 PM
Sorry about the post from coorsman I am using my roommates computer and forgot to log out and back into my account
Old Mar 24, 2008 | 01:50 PM
alwaysonDTR
you don't have to change the frame or the wheels if they will handle the weight, you just have to amke a dog house for the engine like the big trucks have.
Old Mar 25, 2008 | 01:16 AM
What exactly do you mean by a "dog House"
Old Mar 25, 2008 | 01:19 AM
alwaysonDTR
when you cut out the fire wall the new cover for the rear of the engine is called a dog house if its removable.
1stgenatheart
Oct 19, 2009 06:33 AM
joebishop23
Oct 29, 2007 10:19 AM
wreedCTD
27
Sep 30, 2007 09:52 PM
96_12V
Jul 17, 2007 07:03 PM
texasredrider
30
Nov 14, 2004 10:35 PM
