1973 crew cab 5 speed
Old Sep 17, 2011 | 05:58 PM
draginmopars's Avatar
was a 440 auto
decided to go cummins 5 speed
First a little body work
floors rotted
Old Sep 20, 2011 | 10:27 PM
Wow!! Nice job so far...That's a lot of work to ditch those rusty floors. Keeps us up to date on your progress.
Old Sep 21, 2011 | 08:50 PM
Thanks
working on setting up
the drive shaft
using 1410 joints
most of the build is here
http://ramchargercentral.com/diesel-...ns-hauler/100/
Old Sep 21, 2011 | 09:26 PM
engine and trans are ready
just a little porting
Old Sep 23, 2011 | 07:58 PM
got the drive shaft and fuel tank mounts figured out
Now, take it all apart again
re-tube the middle shaft
total length is 154" 3- shafts total
Old Oct 22, 2011 | 03:43 AM
got the cross members locations drilled/bolted
for the drive shafts
the bolt holes were easy to locate using a template
the rear fuel tank cross member
wants to share space
with the emergency brake cables and cargo bulkhead
Old Oct 22, 2011 | 08:44 AM
twichit's Avatar
Nice... um you wouldnt be willing to trade when your done would you?
Old Oct 25, 2011 | 10:40 PM
gayle is working on the cab
she got all the old seam sealer dug out
applied the new
she also got the interior and door post painted
"Hammered" silver paint
to off set the gray interior -dash , seat, carpet
i worked on the exhaust
didn't have enough 3"
So, used 4" and made it look like
a Full-flow muffler just needs welding
Old Oct 25, 2011 | 10:49 PM
also make grease-able hinges
top closed
top open
bottom closed
bottom open ( tube needs welding)
ID of tubing is just large enough
for pin to fit
so that tubing supports the whole pin
instead of 2 little bushings
Old Oct 26, 2011 | 10:39 PM
NCStrokin's Avatar
good lookin project thats def a one of a kind truck with alot of time in it
Old Oct 27, 2011 | 04:15 AM
Thank you
We are building the Ramp Truck to haul the "Rampage"
Old Oct 30, 2011 | 08:24 PM
got the fuel tank mounted
had to step the cargo floor
(1" corragated alum. aircraft flooring)
will use the upper level
for storing the spare tire
the holes in the "X" strips
is for tie downs
can also remove the middle floor
to service the fuel tank/ drive shaft
Old Jan 6, 2013 | 11:50 PM
thought I would revive this old post.
IT's a new year
Hope it gets me back in gear
2010 set me back,
finally get to get back on this project
speaking of gear
Finally found a 3.07 cab chassis rear
long version here>http://ramchargercentral.com/diesel-...ummins-hauler/
Old Mar 26, 2023 | 09:21 AM
Rug_Trucker's Avatar
5 Year Member
You still out there Howard?
DLittle
Jan 16, 2011 12:18 AM
Buddy Stewert
Oct 28, 2010 12:06 AM
Banzai Bob
Mar 3, 2009 01:22 AM
Hot Rod 4
Jan 5, 2007 09:29 PM
Mr. 45
Jan 8, 2003 05:58 PM
