12valve into 2002 dodge ram 24v
Old Aug 6, 2009 | 06:27 PM
woodsRIDER92's Avatar
I dont have the truck yet but once i do as soon as i'm able to put some money into it i was thinking about doing a p-pump conversion, but then i saw how much it would cost. So now im thinking about just putting in a 12valve motor, has anyone done this or know anything about it. The big thing about this conversion would be the gauges (id go all custom instead of trying to make the stock ones work)
Im just planning ahead and doing my research and hopefully this project will follow through
Old Aug 6, 2009 | 08:24 PM
'strokeThis_'07's Avatar
Im actually looking for an 98-02 gasser (cheaper buy-in than diesel?), to drop a 12 valve in. 98s had the new interior, with the 12valve. I would imagine it wouldnt be hard at all to make the gauges work; possibly a computer & gauge assembly, whatever they have (I cant think of the name off the top of my head), from the 98 12valve would be a direct swap. Maybe even work with the current gauges for the 24v app.?
Im in the planning (dreaming) stage right now, and have thought about that exact thing. Thats what I had come up with
Old Aug 7, 2009 | 11:11 AM
I'm thinking if i get the 24valve the motor mounts should be the same, and the 12valve should just drop right in.
but buying a gasser would be cheaper but could you use the fuel tank are they the same as the diesel one??
Old Aug 7, 2009 | 09:20 PM
JLee's Avatar
I think the fuel tank is set up different than the diesel tanks it wouldnt take more than just buying a diesel sending unit and dropping it in
Old Aug 7, 2009 | 09:25 PM
mishkaya's Avatar
The 12V and 24V motor mounts are completely different. You will need a set of 12V motor mounts if you decide to install that engine.
Also, you can make a diesel dash work on a late 2nd gen with a PCM from a 12V 98.
I plan on installing a 12V in a later 2nd gen as soon as funds allow...
Old Aug 8, 2009 | 10:22 AM
rich's Avatar
p pump should be cheaper or the same cost as buying a 12v and all the labor to install. it cost about 4500 for me to install a 12v in my 03 and thats not counting the cost of the motor
Old Aug 8, 2009 | 12:51 PM
is there anyone whos done a p-pump conversion on a 24valve.... if soo how much did it cost you ruffly?
Old Aug 9, 2009 | 12:18 AM
JLee's Avatar
I have the 24v motor mounts on my 93 I put in my chevy
Old Aug 10, 2009 | 01:09 PM
soo would you have to get custom injectors?
iv heard about repopping stock/aftermarket injectors or sumthing? can someone tell me more about this
Diesel_Power_2
Nov 3, 2012 12:01 PM
jpdodge150
15
Aug 15, 2011 06:09 PM
Deezil
40
Mar 3, 2011 05:37 PM
Mike Holmen
23
Jun 12, 2006 03:52 PM
12valve
Feb 16, 2006 03:55 AM
