coolant leak, is it common?
Old Dec 19, 2007 | 11:59 AM
Ghost Ram's Avatar
i have been parked on concrete for the past couple days and have noticed a large spot under my engine. its coolant dripping from the inspection cover on the bellhousing, its running down from the passengers side of the motor somewhere and is gathering on the bottom edge of the block above the oil pan then running down and under the bottom of the bellhousing.
is there a common place for coolant to leak on the passengers side of the motor anywhere? any help would be great, thanks.
Old Dec 19, 2007 | 12:06 PM
davelinde's Avatar
block heater?
gRahAM Diesel's Avatar
Evidently it is quite common. I just had it start leaking on me last month (20 mos old). There is a stainless in appearance coupling on the cooling line that has 2 hose clamps on it and that is where the coolant is prone to leak from. Its on the passenger side, looking down the engine block, behind the turbo, below the trans dipstick if I remember correctly. Just loosen the hose clamps and re-seat; that fixed it for me.
Old Dec 19, 2007 | 12:48 PM
shep1's Avatar
What kind of tools did you use to get at the clamps? I cant get anything to fit the clamps well and get much torque on them. ???
Old Dec 19, 2007 | 07:18 PM
I used one of those cheap ratcheting screwdrivers with the socket adapter but I cant remember the size of the socket; 5/16 maybe. It can be a PITA depending on the orientation of the hose-clamp. It wouldnt budge just trying to tighten, loosen first, re-seat and tighten.
Old Dec 19, 2007 | 11:59 PM
ZachMI2003's Avatar
Take it to the dealer... engine warranty?
Old Dec 20, 2007 | 02:27 PM
Texasimport's Avatar
Yepper. . that little two inch hose behind the turbo. . .Dodge charges $17 if you buy it or for me still warrantied . . . .no more leaky. . . .got a new stearing box at the same time. . .it was leaking too. Dealer treated me right and covered it even though I have slightly oversize tires.
Old Dec 20, 2007 | 02:41 PM
CD in NM's Avatar
That little hose is a warranty item, my dealership just replaced mine. I had already tightened it a couple of times. I used a wrached and a 5/16 socket, first loosened it, reoriented it a little and also reoriented the clamps to make tightening them easier.
FYI, the block heater is up front on the passenger side, in behind the oil filter.
CD
Old Nov 10, 2009 | 11:10 AM
megawhite's Avatar
just traced my leak back to this same hose. CD in NM you say this is a warranty item? is it covered under the motors 100K warranty or normal 36k warranty? thx
Old Nov 10, 2009 | 06:09 PM
Pikeman's Avatar
Mine leaked as well, warranty covered replacement at about 70,000 but it actually started leaking at about 50,000.
Old Nov 10, 2009 | 09:38 PM
Jeff in TD's Avatar
Everyone who experiences this leak seems to have an 06.
Several threads on it.
Old Nov 10, 2009 | 09:52 PM
megawhite's Avatar
Pikeman does ur truck have an extended warranty or was it covered under the motors warranty? Bought mine used and learned the original owner didn't buy the extended warranty.
george7941
Nov 28, 2009 09:28 PM
Thundercloud
17
Oct 30, 2007 09:05 PM
GlennRMK
Dec 12, 2005 04:28 PM
dakar
Jul 6, 2004 12:02 PM
