Wastegated housing or external wategate?
Old Apr 1, 2006 | 06:44 PM
mhuppertz's Avatar
I really like my 16cm, but am I better off getting a wategated housing for my H1C or going with an external wategate?
Old Apr 1, 2006 | 09:42 PM
If you need to go to a wastegated housing to control boost on an H1C, you are probably better off spending the money on a bigger single or twins.
Old Apr 1, 2006 | 10:14 PM
mhuppertz's Avatar
I have a nice 76mm GT35 that I want to use as my bottom turbo, but I need a wategate. Just trying to figure out if it's cheaper to get a wastegated housing for the H1C or an external one.
Old Apr 1, 2006 | 10:41 PM
blowin smoke 03's Avatar
A gt 35 is WAYYYYYY to small for a bottom turbo,But would be great as a top turbo for twins!!!!
Old Apr 1, 2006 | 10:52 PM
mhuppertz's Avatar
Are you sure? It's a 500HP turbo, and came off a big diesel...
Old Apr 2, 2006 | 04:56 PM
I'm very sure,we have a truck with one as a top turbo....It would choke to death as a bottom turbo!!! You said it came on a 500 horse diesel??? Are you sure it's not a gt42 instead of a gt35?????
Old Apr 2, 2006 | 05:39 PM
mhuppertz's Avatar
GT3576 is the model number.
Old Apr 3, 2006 | 05:59 PM
O.K. All it can say is ,I don't know anyone that have ever run a 60 mm or smaller turbo as a bottom turbo with any luck!!!!
Old Apr 3, 2006 | 06:03 PM
mhuppertz's Avatar
This is a 76mm turbo. Someone on this site clued me in to the fact that the size of the turbo is in the part number (GT35 76), and I measured the wheel at 76mm. Is this a good size for the bottom turbo? I don't think 500HP is a realistic goal on a 1st gen, VE Pump'd CTD anyway, but hey, I gotta dream!
Old Apr 3, 2006 | 09:43 PM
JZ 97 SS 1500's Avatar
The 76 is not a reference to the inducer. It is soley a reference to the exducer. A GT3576 comes on a DD S30G. Its only a 4L engine and rated 235hp. No way will that turbo support and sustain 500hp in a single setup on a big Diesel for any extended period. The EGT's would go out of the roof, plus the small shaft design would snap in a heartbeat. We can barely keep GT42's alive in extreme conditions and they use a shaft that is almost .1" larger.
Also keep in mind exducer dictates the pressure the compressor wheel can sustain, not the amount of air it can move.
this may help explain a little....
http://www.forcedinductions.com/help.htm
Old Apr 3, 2006 | 10:03 PM
mhuppertz's Avatar
Thanks much. I'm a newbie on turbos!
Old Apr 3, 2006 | 10:29 PM
He hit the nail on the head!! A GT35r is a great little turbo for a 2.0 liter gas motor and will make 600 and spool extremely well,But the inducer size of that turbo is only a 61mm and 76mm on the exducer and is way to small on the exhaust side for a 5.9 liter engine!!!!!! Thanks JZ for clearing that up!!!!
Old Apr 4, 2006 | 12:03 AM
cumminsdriver635's Avatar
Ill 2nd what wannadiesel said. He hit the nail on the head. After running my 16cm housing for a while(couple years) I modded my 12cm and put it back on. All I can say is that the 16cm is now back on the truck...I have an 18.5cm off a 1st gen laying around too. If I ever get that much fuel I may just go ahead, and put the 18.5 on it(only if I feel I need it, and can spool it fine). Here is the thread I made.
https://www.dieseltruckresource.com/...ad.php?t=98234
Eric
whereswaldo250
Aug 28, 2006 06:04 PM
tinman1911
May 27, 2005 11:06 PM
Jambbii
Sep 14, 2004 12:41 PM
boughtadodge
May 31, 2004 09:20 PM
dart440_72
Jul 12, 2003 12:23 PM
