Launching with a DD
Old Jul 25, 2006 | 12:04 AM
Ph4tty's Avatar
Launching with a DD
I've been trying to figure out the best way to lunch with a DD and a 6 speed. I've tried boosted launches and all I do is spin. Its fun but its not fast with my rwd.
So I've been experimenting and the best I've come up with is starting at 1800 rpm and starting to let the clutch out and as she starts to grab I lay into the throttle and off we go without spin. 2nd, 3rd, 4th, whatever. Ususally third.
BTW I've got 3.54 gears.
Any suggestions???
Old Jul 25, 2006 | 02:57 AM
House's Avatar
try 2nd or 3rd gear
Old Jul 25, 2006 | 05:30 AM
getblown5.9's Avatar
ph4tty...ive been messing around with mine the last 2 weeks. with the 6spd i can get good quick launches in 3rd gear from about 2700rpms, hold it there and start to let it out, once is starts to engage it'll bring the rpms down into the powerband and off you go, when the clutch gets "locked up" fully then you can give 'er heck and roll coal.
this is in 2wd mind you with single rear wheels. the only difference i can see is you having the smarty/tst which is gonna make your power come in stronger and quicker than mine with the comp/injectors.
dont use 2nd gear tho, its too low, you have to shift too quick, 3rd gear will let you get out a little further distance and run thru the full power band/torque curve
Old Jul 25, 2006 | 07:28 AM
blackdiesel's Avatar
Registered
i spin my duals with a 3rd gear launch. not as much as a srw though. lol you need a 4x4
Old Jul 26, 2006 | 08:04 PM
95ram's Avatar
What has always worked for me is bring it up to about 2700 or 3500 . Start letting the clutch out and ride the clutch for a while until its just about fully engaged and then dump it. Or just launch in 4hi.
Old Jul 26, 2006 | 11:17 PM
Ph4tty's Avatar
I'll have to try it like that. High rpm launches always result in excessive wheelspin, but I might be letting the clutch out too quickly. I'm still having trouble finding 4 hi on my rwd
My best 60' to date is like 2.7 spinning all the way It was fun but doesn't make the truck go fast
Old Jul 28, 2006 | 09:30 PM
digger5.9ho's Avatar
You should be able to do 4th. It just needs a little more rpm and pedal work.
Old Jul 28, 2006 | 11:09 PM
Registered
get real soft sticky tires. mine are pretty sticky, but i can still smoke them on a hard launch in 2wd.
01smoker
Competition / Pulls / OffRoad
14
Jul 16, 2006 08:38 PM
kawi600
15
Mar 16, 2006 06:58 PM
blackcloud
19
Mar 8, 2006 11:22 AM
got...DIESEL?
Oct 15, 2005 06:30 PM
yzfr6
Jun 6, 2005 09:54 AM
