hookin chains
Old Jan 29, 2007 | 08:44 PM
06dodgedrw's Avatar
hookin chains
a guy i know has a 95 powerjoke f350 with 35" tires no mods and wants to hook chains hitch to hitch he ses his truck has more nut(read sig for my mods). I need some recomendations on how to pull, being a 6spd with 4.10s, because i have never done it before and it will be in 4wheel drive.
Old Jan 29, 2007 | 08:52 PM
blackdiesel's Avatar
Registered
ohhh youve got the clutch for it! dang this should be easy. put it in 4 low and 2nd gear (i would think) and ease into it.
hooking bumpers isnt about power, its about traction. wait till he starts spinning then take im around the block a coupla times
just dont go get excited and give her heck and break the tires loose! then your toast
Old Jan 29, 2007 | 08:53 PM
rustyshakelford's Avatar
if you have a gooseneck try to use that on your truck and the bumper on his. your gonna kill him. have someone take video
brett
Old Jan 29, 2007 | 09:24 PM
06dodgedrw's Avatar
well right now the truck is on extreme and i had the stock clutch put in because of warrenty work (sorry for got to mention) and the hitchs are regular hitchs and they will be the same hieght so so it will be even.
Old Jan 29, 2007 | 09:33 PM
Registered
sounds like you'll smoke your clutch then. need that DD!
Old Jan 29, 2007 | 09:51 PM
CTDPower11's Avatar
I would think you'll be alright with the stocker clutch for now. Just turn your BDTD down a bit. As long as the F*rd is stock and you keep your traction, you'll be alright! Also, get a 6 inch drop hitch and turn it up. This will make him pull down on you, giving you some added traction...
Old Jan 29, 2007 | 09:55 PM
hottapper1's Avatar
I thought you could only get the g56 3.73s
Old Jan 29, 2007 | 10:08 PM
haloman's Avatar
Yea..... don't hook with chains use tow straps. Lots less chance for collateral damage that way.
TxDiesel007's Avatar
As brian stated
this shouldnt even be a contest.... just dont break the tires loose and if you hook on dirt, lower your tire pressure, as well as on pavement. he has the bigger traction advantage over you with the tires, as well as the weight...
Rick
Old Jan 30, 2007 | 12:03 AM
PourinDiesel's Avatar
If he has an auto you will probably be at a disadvantage.
Manuals have a good chance of killing the motor when the clutch is engaged.
Old Jan 30, 2007 | 02:28 AM
cumminsdriver635's Avatar
Honestly, Id put it on either the stock, or lowest setting with the stock clutch. Its not power that wins this, its traction. Id run 2nd 4 low, and just pull up to 2k rpm's or so, and come out on the clutch smooth. You should be able to walk off with him.
Eric
Old Feb 3, 2007 | 06:41 PM
DODGE 92's Avatar
chain
if i were you id hook up with chain less chance for jumping around heres is a tip put about 22 psi in your tires and if you hook up with a ball hitch make sure you make a turn around it with the chain and hook it up so the chain is up on the hitch that will make it so he pulls down on your truck that will give you added weight you need and dont be scared floor it if you both start spinning with out much movement keep the pedal to the metal and play around with your brakes tapping them so your weels lock up
take it from me worked good when i was pulling a dmax with my old 92
Old Mar 19, 2007 | 03:47 AM
annabelle's Avatar
Let him begin to spin his wheels as you sit there with your brakes locked. Then let your tubo spool up and walk the dog.
Old Mar 20, 2007 | 07:45 PM
RAF's Avatar
RAF
WELL, Did you hook with this guy yet?
I have been waiting for a guy to hook with me. He started with this so I told him to get his bronco and and his mustang hooked together and I'll pull them both around the block. I guess that was enough to shut him up.
CumminsRedneck
Sep 29, 2008 12:05 AM
CumminsRedneck
Sep 22, 2008 01:07 AM
StrokeThisCTD
Competition / Pulls / OffRoad
14
Sep 5, 2005 09:50 PM
FrdRdnk
Aug 28, 2005 12:09 PM
MasseyMan1089
Dec 7, 2004 09:49 PM
