Cheap Sledpulling hitch....
Old Mar 17, 2006 | 08:21 PM
PourinDiesel's Avatar
Weld one of these to a piece of stock for an adjustable unit:
http://www.northerntool.com/webapp/w...40&R=200312040
Old Mar 18, 2006 | 10:04 AM
mtomac's Avatar
most rules require a 3" hole for the hook, this one is only 2.5"
Old Mar 18, 2006 | 10:39 AM
I amended the above post.
Yeah, 2.5" is kinda small.
Old Mar 18, 2006 | 11:14 AM
oestreich84's Avatar
It says it has a 3" ID eye, but it is only rated for 12k pounds.
Old Mar 18, 2006 | 11:53 AM
Your not going to get anything rated for the weight of the sled.
Show me a hitch/clevis/eye that is rated for 40k lbs and 100lbs of drag/resistance that will work easily on our pickups?
Besides many of these are already in use. Big Bad Dodge uses one.
As well as Chris Watsons "smokin" Modified 1400hp truck used one without issue (new truck now).
And just about every truck I seen pulling on the west coast (Duramaxes and Cummins).
Most of the local stuff around here is fabricated from steel plate/stock.
Hell, I have even seen some people use U bolts, and weld clevises together.
What kind of hitch do you pull with or recommend?
Old Mar 18, 2006 | 01:08 PM
I have used a Curt adjustable eye rated for 24k. The Curt part number is E-66. The Buyers is a good eye, I just felt better using one that is rated for 24k.
Old Mar 18, 2006 | 03:21 PM
Willy91's Avatar
We use an EEP adjustable pulling hitch and it works really good.
Old Mar 18, 2006 | 07:08 PM
oestreich,
Does the CURT E66 24K eye attach the same way as the Buyers 12k eye (2 bolts and channel)?
Old Mar 20, 2006 | 10:46 AM
MadGoat's Avatar
I have a hitch similar to the one you mentioned except mine has a 3.5" ID and a longer mounting piece with more adjustment holes in it. They will hold if you gusset the back side a little. I think mine was a little higher $ than that, but mine is a little heavier made.
Overall they seem to work good, but your adjustment incriments are 2" which can get you some times if you aren't careful. With a few more correctly placed holes you should be able to reduce that some.
bobby1stack
Competition / Pulls / OffRoad
18
Mar 19, 2008 10:30 AM
dieselram_04
Aug 23, 2006 09:50 AM
blackdiesel
26
Aug 5, 2006 06:04 PM
GlennRMK
May 1, 2006 08:54 PM
PourinDiesel
15
Mar 23, 2006 09:11 AM
