Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
Cat 416E backhoe fuel problem
Old Jan 13, 2013 | 03:31 PM
INsIdious's Avatar
The machine started running real bad with no power. Changed out the fuel filters and all was well for about 5 minutes. It then started stalling. When it dies. You cannot immediatly restart it. But if you wait 5 or 10 minutes it will fire back up and run for 15 seconds and die again. I hooked a 1 gallon jug of clean fuel to the pump and it will run fine untill the jug empties. I wouldnt think i have already plugged filters after 5 min of running. But i cannot find any problems with the lines. I drained a couple gallons of fuel out of the tank and it looks good. I have noticed that when it dies i can open drain on back filter and hear it suck air. Any thoughts or ideas will be appreciated
Old Jan 13, 2013 | 07:24 PM
Hvytrkmech's Avatar
Tank vent? Is the fuel pump mounted on the front of the engine like bigger cat engines?
Old Jan 14, 2013 | 01:06 AM
pind's Avatar
Tim, I think you nailed it with the tank not venting properly. This is a perfect symptom.
Old Jan 14, 2013 | 09:57 AM
chaikwa's Avatar
Or a rubber fuel line collapsing somewhere?
Old Jan 15, 2013 | 12:11 AM
pind's Avatar
Seriously enough, I have had everything from frozen/plugged vents to dirt/leaves/branches in the tanks,to my personal fave so far, 89 international fuel truck, where the departing driver took care to shove a whole book of meter tickets into the fuel tank. Talk about fun cleaning that up, once we found the problem.
International trucks. 13 letters that spell pure misery... then add a driver.
Old Jan 15, 2013 | 06:59 AM
chaikwa's Avatar
HEY! I like Internationals! Simple, comparatively cheap, and reasonably durable. Cats on the other hand...
Old Jan 15, 2013 | 07:24 PM
Hvytrkmech's Avatar
You spellet it rong Pind, its Intertrashonal.
Old Jan 16, 2013 | 08:01 AM
SmokyDiesel's Avatar
The only good thing international ever made was a manure spreader and even they wouldn't stand behind that!!
Old Jan 16, 2013 | 11:09 AM
pind's Avatar
Ouch
Hey, in newer class 8 trucks, I have to defend international. They make a pretty decent unit for the money, with a large quiet cab and good forward visibility. Not at all like those chached out petercars and kenworths. Nothing better than finding a comfortable position, then looking directly into the overhead console......
Besides, when farmers retire, they need SOMETHING to drive.
how about the original fuel problem?
Old Jan 16, 2013 | 07:00 PM
Moose3406's Avatar
Caterpillar has issued a service letter concerning fuel transfer pump failures on the E-Series backhoes. I wouldn't say it is common for one to fail but I have changed out several in the last year.
Pull the LH panel off of the engine compartment, disconnect the fuel supply line to the IP and run it into a soda bottle. Bump the key to the start position and the pump should fill a 20oz bottle in less than 10 seconds.
If you have a lot of foam or a slow stream, either the pump has failed or the inlet on the fuel filter base is clogged.
If you can give me the backhoes serial # I can get you specific information.
Old Jan 16, 2013 | 07:53 PM
chaikwa's Avatar
Now THAT'S an answer!
Why couldn't YOU do that Pind? Or Tim? Instead of making fun of a very good truck!
Old Jan 16, 2013 | 08:28 PM
Hvytrkmech's Avatar
I still dont think its a pump problem, however with no updated information one can only wonder.
Old Jan 17, 2013 | 11:53 AM
pind's Avatar
wonder wonder who, who wrote the book of loooove???
Commatoze
Aug 22, 2006 10:31 PM
Tiny
Jul 10, 2005 07:36 PM
Tommy93w350
Jul 27, 2004 03:53 PM
Crimedog
May 28, 2004 03:56 PM
magnumduckdog
Feb 3, 2004 11:57 AM
