Twins, Twins, Twins, Twins, Twins............
Old Oct 14, 2011 | 10:21 AM
  #481
dodgediesel's Avatar
Originally Posted by Bankdude
Hey Jaimie, really dumb question, but are you sure those are 90's and not something much bigger? That is alot of extra heat!
The boxes say new DDP 90's....
Old Oct 14, 2011 | 12:04 PM
  #482
Bankdude's Avatar
I was thinking bigger sticks could be the next project for me, but I would sure hate to go back to 1400deg.
Hopefully it turns out to be something simple.
Old Oct 14, 2011 | 02:18 PM
  #483
goatbrain5.9's Avatar
When I was running my 90's I barely ever saw 1200 even on the hardest of pulls. I however had an arson III kit. I would install your new cp3 and try again before anything.
Old Oct 14, 2011 | 02:56 PM
  #484
ramped's Avatar
hey guys im not from your area. But I just wanted to say thank you for one of the most informative threads I have come across on dtr. MANY of my compound questions were answered thank you again!
Old Oct 15, 2011 | 09:38 AM
  #485
Mike Holmen's Avatar
The Guru
We are in the process of changing twins configuration, so some of this will look completely different. Hoping in the next few weeks we will have a prototype done up.
Old Oct 15, 2011 | 07:55 PM
  #486
Put in the new pump and no difference. Something tells me boost leaks again?
Old Oct 15, 2011 | 08:09 PM
  #487
StealthDiesel's Avatar
No difference in peak EGT's or in rail pressure?
If you are still running Revo TNT level 9 all defaults try running Revo TNT level 7 all defaults.
In nearly all cases including mine, level 7 makes more power than level 9.
Old Oct 15, 2011 | 10:00 PM
  #488
Tate's Avatar
Did your rail pressure go up with the new pump? If your pressure is down, then I doubt its boost leaks causing your medium EGT's. 1400 really isn't that hot anyway.
Old Oct 15, 2011 | 11:29 PM
  #489
I'm ok with it all. An intercooler will drop it to 1300 and that's where I wanna be. Over all, very impressed with it all. Just got to find that oil fitting now Tate. What size and ends am I looking for?? Then that oil feed line to the big turbo will fit perfect and we are off to the races!!!!!
Old Oct 15, 2011 | 11:37 PM
  #490
Tate's Avatar
Spend less money and buy a cam. Broader powerband and cooler EGT's. $1500 for a 100 degree drop (if you're lucky) is a lot of coin. $600 for a cam is way better.
You need a 12mm ORB to -6 JIC. You could talk to Vulcan, they had those fittings for the fuel system. Or keep bugging Ability. Sooner or later, they are bound to get the proper fittings.
Old Oct 16, 2011 | 12:06 AM
  #491
Isn't a cam swap hard to do?
Old Oct 16, 2011 | 12:13 AM
  #492
Like this one?
http://www.vulcanperformance.com/Met...mm-p/m1206.htm
Old Oct 16, 2011 | 09:50 AM
  #493
dvst8r's Avatar
A little time consuming, but not difficult.
Old Oct 16, 2011 | 10:05 AM
  #494
Diesel Dave2's Avatar
Pickin on the wrong admin...
Watched Tater install a cam in his 24V...I've done cams in V8 gassers...Can't be no worse than a CR...Days work with no beer...
Old Oct 16, 2011 | 10:28 AM
  #495
The Guru
$650 is just for the camshaft, don't forget the tappets.
The front end of the truck has to come apart. If it was me, I would also do the oring in the head as well, during the cam swap. Probably also do some leak repair as well. Probably a good day of work, but nothing to difficult. I also suggest degreeing the cam and doing the valve clearance checks. Nothing is worse than doing a cam swap only to smack intake/exhaust valves.
I agree with Tate, probably some of the best money spent. A cam install is easy as pie when the engine is out of the truck. Its abit of fishing if the engine is still installed.
I suggest getting a colt stage 4 or the new hamilton 188/220
