o-ring cutting in calgary ?
You want to get a 12v or 24v head cut? Good luck, real hard to find anyone locally. I knew someone from Balzac area did orings, but I would have to do a check see. I wanted to buy the tool to cut the head, but its pricey. Swamp donkey has a tool to cut the block to install o-rings. I think Tate had his done in edmonton, Nisku area.
Do You know what/how you want the orings cut? What diameter size of wire and oring placement? I think most use 39 to 41 thou wire and protrusion is 9-12 thou. I like more protrusion and using the thicker wire for better sealing. What grade of head studs you going with? Most of my orings bite into the inner wire of the head gasket (fire ring)
Here the sweet tool....
http://www.bhjproducts.com/bhj_downl...atalog_p14.pdf
Its pricey, $2400 USD, but thats was last years price
oh mike that cutter is swanky......me likey.
the Isky cutter swamp donkey used on his block was a borrowed unit from someone up there. I asked him about that before. and the isky cutter only does the engine block IIRC.
There is a need.
