Just dreamin here
Old Oct 15, 2009 | 10:04 PM
roxxx's Avatar
Just dreamin here
Could this motor work in the dodge truck ? granted it is worth more than my truck is worth
http://edmonton.kijiji.ca/c-cars-veh...AdIdZ152084507
Old Oct 15, 2009 | 10:11 PM
1-5-3-6-2-4's Avatar
is he on glue? $8500 for a dirty stock engine. for that price there should be a dirty Freightliner wrapped around it still. maybe I'm a skeptic. but I don't believe it has 7,500 kms on it. and out of a FL70.....something doesn't jive to me.
that answer is yes to your question. but you'd need a dodge flywheel housing. thats an SAE flywheel housing on it. well you could put an allison on that SAE housing though.
Old Oct 15, 2009 | 10:20 PM
Tate's Avatar
lmfao, classic line!
5.9's did come in FL70's, Paul's old FL had a 12v in it. $8500 is rediculously high. The pistons would be a bit different from the 215/235 pistons, but not enough to justify spending an extra $6500 on it.
Old Oct 15, 2009 | 11:03 PM
roxxx's Avatar
Ha well then what am i looking for? Which pump am i looking for and from what ... there is no way I will ever run a VP again Seein as Luke can put a chevy on a F450 I figure how about a 1 st gen on a 12 or 24 valve chassis with a P-pumped 24 valve It wont be this one I am messin with but may have a line on another 1 st gen
Old Oct 16, 2009 | 11:07 AM
Mike Holmen's Avatar
The Guru
I would look for a 2nd gen 12V engine. Find an engine that has a P7100 injection pump on it. A 24V with a P7100 would also work, but thats more $$$. the cheapest solution is to get a 12V. You can find them for under $1k. Sometimes you can buy a truck with the motor. Pull the motor and sell the truck, and make money. If you have tons of money, you could put in a common rail motor into the rideThat would turn heads in a 1st gen truck. Painless makes a wiring harness for the common rail. For $7500, thats crazy. I have bought four 5.9L, for less than 4k, so whats that guy on
Old Oct 16, 2009 | 11:29 AM
winkdemon's Avatar
for the price you can get a hole Freightliner
Old Oct 16, 2009 | 11:49 AM
roxxx's Avatar
yea yea I know. but just churn the ideas. I know it is high, I have always wanted to do a 24v P-pump just cuz ,and after seeing what luke is up to i got thinking about a 1 st gen on a 2 gen chassis . I know they are bricks as far as aerodynamics but man that would be cool
.............or yes even a CR motor
Old Oct 16, 2009 | 12:24 PM
winkdemon's Avatar
can be done i was going to put a second gen body on my 1st frame . then found the old school body
Old Oct 16, 2009 | 08:51 PM
The Guru
The only real advantage to running the newer 12V or 24v engine is the second drain. Most of this stuff is getting cheaper, as the world goes to the 6.7L engine. Soon, the 5.9L will be distant memory for pick-ups. You could also slam in a 6.7L and be real whizzy. How badly do you want a 24V engine?
Old Oct 16, 2009 | 09:09 PM
ccmckee's Avatar
I looked at that ad and i was half expecting it to be the engine out of Paul's FL70 That engine was fubarred 11 head gaskets later with a warped block between 2 & 3, we got good at doing HG's 4 hours in and out
Old Oct 16, 2009 | 09:31 PM
roxxx's Avatar
Wow!!!! noted heh heh guess i know who i will ask if need ever arises
Old Oct 16, 2009 | 09:36 PM
roxxx's Avatar
depends on my rear Axle and whats wrong. I talked to a guy who knows his gears and kinda told him what the old critter was sounding like ....... he said before i change bearings pop the Dif cover and go fishing for metal
then look at the carrier
Old Oct 17, 2009 | 12:55 AM
ccmckee's Avatar
definately check the carrier, my bearings ate into my carrier,$2500 later and it wa all rebuilt.
Old Oct 18, 2009 | 06:48 PM
The Guru
I would definately pop off the rear diff cover and see what you have. If its ugly, you could find another diff. The parts should be out there. Sometimes its just easier to replace than to rebuild.
Wild4kst8
Oct 12, 2009 07:11 PM
12valve@heart
Feb 26, 2007 08:20 AM
Bocifus
Mar 30, 2005 12:55 PM
crobtex
Dec 8, 2004 09:32 PM
Dieseldude4x4
Oct 17, 2002 04:58 PM
