I need help figuring this one out...
No you can't see the ball and spring in the return banjo without removing it. What you see on the outside of the banjo head is not the ball. That's just how the non adjustable style is made.
The ball will be at the bolt tip. Not at the head.
I have the cummins part number at home. But I am in the geometric center of no where rig now looking at a savanna drilling rig.
Sent from my Desire HD using Tapatalk
The Guru
Typically you can hear the valve relieving, mine makes a noise when open fully. I would guess it would pop at around 16psi. Is all the connector nuts tight? You have decent orings on the cross tubes. Is the lines going to the VP tight? You could put in a check valve on the inlet side of the VP, as the inlet side might be bleeding down. About 90% of VP hard starting issues are caused by those injector lines loosing the seal requirements. Sure miss driving my old 02 VP ride, been awhile for me as well.
Top's Younger Twin
I wrote down the part numbers off the bolt when I had it out. I think we will replace it.
I can do the seals again on the injector lines. I need part numbers for them though.
We are running 21 psi, Should I turn the pump down some? It runs real nice once its running.
Thanks
dont know if this has been suggested or not.
on equipment ive seen a tank breather plugged and after it is off it was a hard start caused by a slight vaccum in the tank. could try with cap off.
and on another peice it was a weak/worn injection pump.
soory thats all i got
Totallyrad
07-01-2012 08:55 PM
fullbore farmer
09-10-2007 11:13 PM
MmmDieselFumes
07-16-2007 08:10 AM
