2002 dually rear rotor replacement
Old Aug 11, 2011 | 10:54 PM
Swamp_Donkey's Avatar
I am trying to change out a rotor on my dads 02 3500 dually. After pounding away with a sledge hammer with no results I did a search on here. Looks like I need to remove the axle shaft and the wheel bearings. Need 2 quick questions answered. How tight do I tighten up the wheel bearing on re-assembly? And does the new rotor come complete with studs? Just going to borrow a 2 9/16 socket for the job. Any other tips would be appreciated.
Old Aug 12, 2011 | 01:59 AM
Tate's Avatar
If you search my name, I know of I've posted this before. But IIRC, tighten up to 120 ft-lbs, then loosen a 1/4 turn. Also, IIRC, the rotor bolts to the hub, its not the studs that hold it in place. So your original studs should stay in place.
mariner
Jul 10, 2010 05:04 AM
Southern Pride
Feb 17, 2010 10:24 AM
Crash101
Oct 20, 2008 05:58 PM
docram
Nov 7, 2006 11:16 PM
