Ab Tool Sharing Program
Old Jan 15, 2010 | 10:51 PM
  #46
Mike Holmen's Avatar
The Guru
Guys, I need to borrow a set of inside mics? Stuff to measure inside cylinder bore diameters and crank measurements. Thanks
Old Jan 15, 2010 | 11:00 PM
  #47
pistazie's Avatar
Alberta wide loan:
Engine hoist - Tate
Tranny jack - Tate
Calgary:
Timing kit w/light - Tate
Engine hoist - Winkdemon
Warm shop - Winkdemon
3rd gen tube puller - Winkdemon
3rd gen injector puller - Winkdemon
Tire machine - Winkdemon
Code reader - ccmckee
Various pullers - ccmckee
Balljoint press - ccmckee
Delivery valve socket - ccmckee
Barring tool - ccmckee
Inside race slide puller (large and small) - billie
AC puller - billie
Bearing splitter/puller - billie (separates bearings that are pressed close to collars)
Cylinder hone - billie
175A mig - billie (for use at my place only)
Red Deer:
VP puller tool - dodgediesel
Big Shop - dodgediesel
Grande Prairie:
Code reader - rage_blue
Specialty sockets - rage_blue
Coolant system pressure tester - rage_blue
Vac pump - rage_blue
Steering wheel puller - rage_blue
Torque Wrenches - rage_blue
Ft. McMurray/Wandering River:
Timing kit - northernwheeler
barring tool - northernwheeler
large warm shop - northernwheeler
tire machine - northernwheeler
tire siper - northernwheeler
Engine hoist - morkable
Engine stand - morkable
Car hauler - morkable
mig welder - morkable
Edmonton:
welder tig/stick - kennyblatz
tire groover/siper - kennyblatz
barring tool - pistazie
porter cable polisher - pistazie
Porter cable - to make it look good!
Old Jan 16, 2010 | 08:52 AM
  #48
JHansen's Avatar
Luke's right-a rail cap to isolate each one and a set of special banjo bolts to measure the return flow to see which one (or ones) are leaking by. There's also a harness connector to plug in to check the electrical side with a multimeter-I have that too. Combined with the DRB to do a cylinder kill, you should be able to pin down the offending culprit (or culprits).
I should go through my stuff to itemize it all I guess. I know I also have a 24 valve spring compressor (as does Luke), a compression tester with all the adapters to do 12 or 24 valve, some funny sockets for the tamperproof bolts on a VE pump. Some special flare sockets from Snap-On for injector lines. A blacklight kit for finding leaks-I have adapters for AC and dyes for pretty much anything-used it to find a stubborn oil leak on my '01. Somewhere in my goodies I have a combustion leak tester too that I bought to check for a head gasket leak-but have yet to use. Can you see a developing problem here?
Old Jan 16, 2010 | 08:59 AM
  #49
JHansen's Avatar
Alberta wide loan:
Engine hoist - Tate
Tranny jack - Tate
Calgary:
AC puller - billie
Red Deer:
Grande Prairie:
Edmonton:
Drumheller/Hanna area:
DRB III scan tool - JHansen
injector pop tester - JHansen
Raytek infrared heat gun - JHansen
compression tester - JHansen
blacklight leak finder - JHansen
combustion leak finder - JHansen
CR injector puller - JHansen
CR injector diagnostic tools - JHansen
fuel system pressure tester - JHansen
cooling system pressure tester - JHansen
oil cooler pressure tester - JHansen
24 valve spring compressor - JHansen
VE pump special sockets - JHansen
VE/P7100 timing tools - JHansen
timing pulse generator & light - JHansen
VP44 hotbox - JHansen
air system pressure testers - JHansen
ball joint press - JHansen
specialized diff tools - JHansen
mig/stick welder - JHansen
plasma cutter - JHansen
chopsaw & bandsaw - JHansen
20 ton press - JHansen
rim clamp tire machine - JHansen
misc. pullers - JHansen
air tools out the wazoo - JHansen
I'll add to this as I go through my tool chest...
Old Jan 16, 2010 | 11:58 AM
  #50
Dr. Evil's Avatar
Wow thats quite a list Jason - how come I didnt know you when I lived in Hanna??...excellent stuff man.
Old Jan 16, 2010 | 12:46 PM
  #51
Swamp_Donkey's Avatar
Jason,
You want a new neighbour? Might move to Bymoore in Reggies old house. LOL
Old Jan 16, 2010 | 05:42 PM
  #52
Tate's Avatar
And I think Jason wins! BTW, I will be at Sheerness at the end of the month, working days (boo!), so if you are free, we should go for supper one night.
Old Jan 16, 2010 | 06:35 PM
  #53
morkable's Avatar
I think I am going to just move into his garage,, LOL....
Old Jan 16, 2010 | 07:21 PM
  #54
rage_blue's Avatar
thans jhanson, WE buildt a cap and just go right to the plug for ohming. don't have banjo bolts to measure feul return. you just cap each injector individually and see what the return line pressure is? condeme the injector that drops return pressure the most when capped i assume?
Old Jan 17, 2010 | 12:05 AM
  #55
han solo's Avatar
There is abit more to CR thou, need program like insite or the drb to up the rail pressure while the engine is @ idle. Then the fuel return test is done. Rail pressure is around 22,000psi. I wont really want to trust a home made cap. Yes I have do the test @ work. I have turning tool, 24 valve spring comp tool from source auto, 6" tap for doing head studs. Rest of the tools I need for fixing broken DD/MBE engines. This is from the LLoydminster area, can mail them thou
Old Jan 17, 2010 | 01:35 AM
  #56
nickg's Avatar
I copy and pasted to the growing list, the things that I have that I can lend
Nick
Alberta wide loan:
Engine hoist - Tate
Tranny jack - Tate
Calgary:
AC puller - billie
Red Deer:
Grande Prairie:
Edmonton:
Snap-on scanner "red brick"(veh specific till 98, then generic, gotta get it updated someday)- Nick
pitman arm puller (heavy duty)- Nick
Various pullers/ cheap steering wheel puller that works good for pulling VP's
engine hoist/ tranny adapter for floor jack.- Nick
Coolant pressure checker.- Nick
10 ton press. -Nick
Chopsaw.- Nick
engine stand (750lb, doubt it would hold a cummins)-Nick
Torque wrenches (3/8, 1/2, & 3/8 inch pounds) -Nick
sawzall -Nick
Old Jan 17, 2010 | 02:13 AM
  #57
winkdemon's Avatar
Nick
Alberta wide loan:
Engine hoist - Tate
Tranny jack - Tate
Calgary:
10,000 lbs hoist -winkdemon
car trailer - winkdemon
20 sizes of hammers -winkdemon
welder mig -winkdemon
coolant pressure tester -winkdemon
scan tool -winkdemon
torchs -winkdemon
ball joint press - winkdemon
AC puller - billie
Red Deer:
Grande Prairie:
Edmonton:
10 ton press. -Nick
Chopsaw.- Nick
sawzall -Nick
I added a few things on there i own and run a shop so in have many things that need to be used and if anyone needs stuff , i can most of the time help , as long as you replace what you use
Old Jan 17, 2010 | 10:31 AM
  #58
JHansen's Avatar
Our shop sucks....someday I'll win the lottery and build a decent one. We do have lots of tools though-I subscribe to the philosophy that you might as well buy the tool and do it yourself-then the tool will be there for the next time it's needed. I thought of a couple more things that I have kicking around that I bought intending to use in the 'patch but never did: an ultrasonic leak detector and an ultrasonic thickness gauge. I'll add them to the list after I go through the shop to see what other goodies are hiding in cabinets etc....
That sounds good Tate-I think you still have my cell #. I can't see anything too radical going on around the plant in February as long as the weather stays decent-all our services will be done next week and our new maintenance foreman has our little boosters pushed out to 2500 hour intervals now so as long as nothing unscheduled pops up I should be reasonably free. John, Reggie sold his house in Byemoor a couple years ago so you're SOL there-I'm sure we could find you some nice accomodations though if you want to move down here
Old Jan 21, 2010 | 10:40 AM
  #59
pgdsm's Avatar
I'm in edm and I have a cheap steering wheel puller that's great for vp's also got an obdII code reader.
If I stick around edm I will get a shop and get my tools out of storage. Then I will have a bunch more to offer.
If anyone needs some welding done I can do it if you provide the machine.
bluebull
Aug 16, 2007 04:51 PM
Alaskaworktruck
May 30, 2007 01:29 PM
jmccart
Mar 24, 2007 11:48 PM
jmccart
Mar 24, 2007 09:34 AM
