48re question - '06 to '03?
Old Sep 29, 2010 | 08:56 PM
1-5-3-6-2-4's Avatar
hey guys a bud has a '03 dually 48re, slipping bad. he wants to get this other one out of an '06. are they plug and play between those years?
Old Sep 29, 2010 | 10:15 PM
DWeiler's Avatar
Some of the early 03 had the 47RE in them---i guess just to use up the old stock before the 48RE came out---kinda like my 07 with a 5.9,use them up too until the 6.7 were installed.The reason i jumped on my 07---IMHO the last of the best(no flame or war intended).I thought the 06/07 had different/improved programming for the tranny----something to do with lock-up,might not work with the 03 motors programming.PS sorry had to reread your post ----did not see the 48RE
Old Sep 29, 2010 | 10:19 PM
morkable's Avatar
the 03 has a completely different valve body, the newer trucks have a completely electronic vb, the 03 04 have a tv cable
Old Sep 29, 2010 | 11:12 PM
ok thanks. so its not really a go for him.
now a second question for me.
if I picked up an '04 with 48re can I put the billet triple disk converter on it from my 47rh?
Old Sep 29, 2010 | 11:33 PM
morkable's Avatar
sorta,,, I am not sure how the tcm will handle that
Old Sep 29, 2010 | 11:37 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Here is my input.......none......You guys are so smart on this 3rd gen stuff.....Sorry....wasting tread space..
Old Sep 30, 2010 | 07:14 AM
nickg's Avatar
I dont know, what is interchangeable for sure , but I had a VB built for my 01, by DTT, long story short, it had to be sent back twice because it did not work, they tested it in a 2nd gen and a third gen, to confirm it was indeed a VB failure, their response was if any faults would show up it would be because the 3rd gen runs higher pressures.
I'm sure a tranny shop whould be able to confirm interchangability
Old Sep 30, 2010 | 09:19 AM
Mike Holmen's Avatar
The Guru
Could get a stand alone programmer, for the transmission, but at that point why run a RE48. If you're going to spend the money, I would look into a 5R110 (5 speed ford) and a stand alone. A stock 5R110 is stronger than a slightly modified RE48. If you're going to tow anything, you'll rather have the 5 speed anyways.
Old Oct 1, 2010 | 12:16 PM
Eric @ ATS's Avatar
You'd have to come up with a bracket for the TV cable, but that's about it.
CTDCAL
Sep 27, 2003 03:22 PM
dansdad
Sep 6, 2003 09:00 PM
Sittenbull2
May 30, 2003 11:16 PM
Sittenbull2
May 15, 2003 04:15 AM
malibu
Feb 5, 2003 08:22 AM
