Popping sound when turning left ???
When I turn left, full lock or close to it I hear a pop sound. This is while turning at low speeds as in parking and backing my trailer.
Anyone else had this happen and know what it is ???
Mine has done this since day 1 when i brought it home and backed in the driveway, i was told it is a spacer so that the tires dont oversteer. Because with the bigger steering pump 30% than 08 and older trucks they need to integrate this.
My power steering pump also has a whine when it is turned the whole way out either way, again dealer says i'll have to live with it he says "when you have the steering wheel turned the whole way open in either direction with this bigger steering box it will make all kinds of funny noises, they all do it so far it is normal any further problems call us and we will look into it"
That is rediculous the mechanic told you that. Although there will be some noise when maxed out, it has nothing to do with the steering box. Its all about the max pressure. Anyway, research the threads on here about the steering noises everyone is having. I have had the dealer replace the steering box under warranty. Mine was making crazy noises and we were certain it had nothing to do with the pump. Several of the guys have had this same issue.
I ordered called bilstein they told me i need the 5100 all that is is the replacement oem, i want the 7100 with the correction of the right tire pull which i also have with 33's and he kept telling me i need the 5100. If you read on theyre site all the 5100 does is literally replace a broken stock one, and the 7100 is the real deal that will actually do something, thats what all these other guys run
Mine pops with the steering brace installed also. I feel it pop under my feet where the axle arm links hook to the frame. It mainly when I am turning going over bumps. Did it with my stock wheels and with the 22.5's
Thanks for the input, i have a 2006 ram 2500 work truck its just a gas but same front end and it has been in and out of the shop every couple months the front end has been changed twice, ball joints axle joint wheel joints pittman arm, etc and it still make a helacious grinding noise, so after driving that thing the last 4 years i was praying before i bought one personally dodge had looked into or at least tried to fix these **** things but i guess not
Buela
Sep 12, 2015 11:08 PM
buldaawg
13
Apr 23, 2008 09:17 PM
Bobcat698
Jun 4, 2006 08:21 AM
