Key Fob functions
Key Fob functions
I just found out that my key fob controls the windows. I was never told about this function. I just realized when I pushed the unlock button to many times that the windows went down. So after trying a combation of buttons I figured out that if I press unlock 4 times and hold on the fourth I can control how far the front two windows lower. I wonder what else I'm not getting full use of from not being informed.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
ya only have to push it twice and on the 2nd push, hold it and it will roll the windows down fully or partially down (however long you hold the button)
To roll back up insert key into ignition, turn key, use short fat finger to lift windows switch.
The window sensitivity is good but bad. On ruff roads I have to fight to get them to roll up. If I hit a bump while there rolling up, there they go back down.
push and hold the window button down and count to 5 while still pushing it down, then go up and hold and count to 5 then go back down. then click the auto feature to make sure it took. this sometimes "resets" the system and may correct the issue but not 100% positive it will.
Chris
I had to check mine yesterday and voila!! it worked. I told a co-worker who has a 1500 and his worked as well. We both have 2010's and never were told of this function. Any other little tricks that we all should know?
