installed gauges 2011
Old Jan 13, 2011 | 06:40 PM
icso9131's Avatar
Those things look SICK!!!
Does Pricol have a FRP gauge?
Thank you for finding the gauges I'm spending my money on. Thank you, Thank you good sir.
Those are REALLY NICE. I'm not going to be able to sleep tonight now...
If you wouldn't mind, could you PM the price of the set up?
Old Jan 16, 2011 | 09:01 AM
Evildiesel's Avatar
Okay, I found a 12v wire to tap into, its pink with a yellow stripe coming out of a grey connector about where the clutch pedal would be, If Im following it correctly it originally powers the rear 12v outlet. Ill post a picture later. Still working on an illumination wire but I think I must have wired something improperly because when I apply voltage to the illumination wire on the gauges I get nothing, Ill have to work on that Monday. My NEW problem is the fact that they removed all the banjo bolt fittings between the lift pump all the way to the rail pump, making the banjo fitting I recieved useless. Im not familiar with the type of connection they are using now but Im hoping someone else here is and can show me a fitting I can purchase to adapt to the sensor. I called Manor but they havent done an install on a '10+ yet so they suggested I turn to the forums. Not being able to purchase a service manual is really starting to p!$$ me off. If anyone could help Id appreciate it, Id rather not guess and check when it comes to the fuel system.
Old Jan 16, 2011 | 09:03 AM
Blake Clark's Avatar
Its another 200 bucks but money well spent.
Get a Glacier Diesel MK2 and big line kit. Secondary 2 micron filtration and will allow you to put a fuel pressure fitting inline just before the pump.
Old Jan 16, 2011 | 09:58 AM
Evildiesel's Avatar
So of course theyre sold out...lol
cowboy1814
Mar 10, 2014 10:19 AM
Bradjun1
Mar 10, 2011 06:41 PM
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
