Fuel additive
Old 04-03-2018, 06:58 PM
bishgeo's Avatar
Fuel additive
safe to run in the 2018 rig.
Old 04-04-2018, 08:56 AM
johnh's Avatar
that's one gallon of #2 diesel fuel
Old 04-05-2018, 02:45 AM
NC Ram's Avatar
What are you having problems with that you hope this product will solve?
Old 05-03-2018, 11:13 PM
iah145ca's Avatar
Opti-Lube XPD is the ultimate in performance diesel fuel additives. The best diesel fuel additive on the market.
Opti-Lube XPD’s primary purpose is to increase the lubricity properties of ultra low sulfur diesels (ULSD). However, improving Lubricity is just the beginning. XPD Formula is a multi-functional additive for upgrading the quality and enhancing the performance of diesel fuels.
XPD simultaneously improves lubricity, efficiency, cleans injectors, improves Cetane by up to 3 points and contains an anti-gel to keep your fuel flowing down to -10° F.* XPD does not contain any harmful alcohol.
Old 05-04-2018, 08:10 AM
johnh's Avatar
it looks like an advertising ad to me!!!!
Old 05-04-2018, 08:12 AM
iah145ca's Avatar
Just copied it off the optic lube page, so i guess it is an advertisement. It answered the question though.
Old 05-05-2018, 02:47 AM
NC Ram's Avatar
The ad tells what the product claims it does.
I was wondering what type of problems the poster was experiencing that created the need for this product.
I still don't know what it's going Nc to fix in his truck. The ram Manual says not to use fuel additives.
Old 05-19-2018, 11:39 AM
Adaminak's Avatar
I ran this for a while in my 2004 and it made a noticeable difference in engine noise, idle smoothness and I gained a whopping 0.2 mpg. I've also run the summer treatment, and that did the same thing, but I gained 0.3 mpg. The only reason I kept using it was because a) I bought a gallon and was only driving 50 miles a week, so it lasted forever, and b) I figured the smoother and quieter idle was most likely a byproduct of better ignition and pump lubrication, and that couldn't be a bad thing.
Old 06-18-2018, 10:44 PM
mossyoak11's Avatar
following to see what the determination is on using additives in 4th gens.. i ran optilube in my 05, and it was fantastic stuff.... driving a '14 now and haven't used lubricant, but would like to
Old 09-02-2018, 11:47 PM
65fury's Avatar
Ive used fuel additives in all my diesels and even gassers. Ive worked on enough cars and trucks and seen the byproduct of todays crappy fuels, lower octane and lower cetane fuels leave carbon build up in the motor.
I know plenty of people will disagree and im not looking to get into the science of it, im just going to provide my 2 cents.
I like Howes lubricant and Ive seen my MPG go up 1mpg when mixed with a cetane booster. A new cetane booster i tried was by royal purple and thats when i saw the big boost in mpg. I drive over 500 miles a week and its the same route to and from work so i know what my normal average mpgs are.
I usually run standynes cetane booster, a local fuel injection shop highly recommended them to me years ago and ive always had good results.
Here in CA the cetane rating in diesel is lower than most other states.
jason
Old 09-07-2018, 12:16 AM
"Gomer Pyle"
New2Diesel's Avatar
Silver Bottle, has Cummins logo on it. They’ve got a whitebottle that’s got anti-gelling for cold weather
Zeppe807
25
11-16-2010 08:00 AM
rjmelehan
0
11-30-2009 01:02 PM
12-23-2002 07:42 PM
doodah
16
12-14-2002 10:20 AM
MARKY MARK
11-19-2002 09:37 PM
Quick Reply: Fuel additive
