edge insight cts
I believe you will need the EGT probe and drill and tap the manifold. As far as I know Ford's are the only ones that read egt's through the obd II. My 2009 needed to be drilled with my Insight. Not sure what gauge direction we'll go with my wife's 2012.
Yes it will read the downstream EGT's. However they are not a very accurate indication of what your pre-turbo EGT's are as they are there more for when the truck regens than for regular temperature monitoring. For giggles I monitored the post turbo EGT's for a while on one of the PID's and at times there was a 500* spread between my pre-turbo and the Edge's post-turbo numbers.
I would recommend buying the pyro kit and installing it pre-turbo. I have the kit and it works great...
ironbrew
Jul 1, 2012 09:14 PM
FishBio31
Nov 1, 2010 09:30 PM
FishBio31
Jun 21, 2010 09:48 PM
FishBio31
Jun 17, 2010 05:26 PM
FishBio31
0
Jun 17, 2010 01:10 PM
