AFE Atlas Exhaust
AFE Atlas Exhaust
So I went with the AFE Atlas turbo back delete exhaust. I have now ran into a problem, I do not know if I am just exhaust challenged or what. After installing most of the exhaust, the axle over piece is off by about 5 inches. When I say this, I mean the exhaust is about five inches too long, the truck is on a lift so at least it is easy access. Should I just cut the pipe and call it a day, or do you think I have something off somewhere else? Commence chastising.
I have the AFE tbe and it all fit perfect, if your all the way in at each joint and the tail section will fit correctly if you cut it, then go for it. Is your ccsb.
sawboywv1
07-15-2004 10:31 AM
