project extended range
Old Apr 5, 2012 | 12:55 AM
cbrahs's Avatar
well project extended range has taken another turn. Just got ahold of a 120 gallon diamond plate fuel tank with external pump for the sweet price of FREE. traded my 85 gallon tank for it. Have a welder buddy of mine going to weld bungs in it for me for my feed set up and also going to weld a plate on the top so I can install a sending unit to monitor the level via an autometer gauge. 160 gallons of sweet #2 nectar should get me where I need to go. filling it will suck but add up all the stops with a 35 gallon tank to make it where I am wanting to go and you still pay the same money and hey, with fuel prices I can pick and choose my fill locations based on price not need. Will post pics. going to attempt to get it fitted this weekend but have a crazy schedule
Old Apr 5, 2012 | 10:29 AM
megacab2500's Avatar
Good deal Chris . How many miles does your truck have now?
Old Apr 6, 2012 | 03:40 AM
Blake Clark's Avatar
Free? Free!
Hell, if its free.....
Ill take TWO!
Thats gonna be a lot of fuel. I heartily approve.
Got my 90 gallons RDS gravity plumbed into my factory tank for a total of 125 gallons on the run for me. Wouldnt have it any other way.
Old Apr 6, 2012 | 09:11 AM
Grand Geek's Avatar
Are you sure that's not a yard tank?? I cant wait to see your tank install this time.. Its going to be sweet just like the last time..
Old Apr 6, 2012 | 10:23 AM
MOJO1's Avatar
Post a Picture if you dont mind. Thanks J,C,
Old Apr 6, 2012 | 09:40 PM
Spooler's Avatar
I need to do this mod myself. It's always a worry trying to get fuel when pulling the trailer.
Old Apr 7, 2012 | 10:39 AM
cbrahs's Avatar
this is what I had installed.
This is what is going in. We are purging the tank as I am welding bungs to the drivers side of it to plumb into my current FASS pump to transfer fuel. Also welding a plate on the top for the sending unit. Going to install a gauge on the pillar to monitor levels while traveling. Have a pump for the passenger side just in case I need to fill equipment etc so thats an added bonus
Old Apr 7, 2012 | 07:13 PM
greasy1's Avatar
Anything over 110 gal = placards and hazmat lic.
Old Apr 7, 2012 | 07:15 PM
What regulatory code is that from?
And is that for a single volume, or a total volume?
Old Apr 7, 2012 | 07:25 PM
greasy1's Avatar
DOT single volume
Old Apr 7, 2012 | 07:26 PM
Any links, Id like to read up on this. Everything I am seeing is 119 gallons.
Old Apr 7, 2012 | 07:29 PM
greasy1's Avatar
Check the DOT hazmat page
Old Apr 7, 2012 | 07:33 PM
I could better accomplish time travel then find anything quick in those codes...
Old Apr 7, 2012 | 07:37 PM
greasy1's Avatar
I know the feeling. I took the test about 3 weeks ago and it's not much better!
Old Apr 8, 2012 | 01:32 AM
cbrahs's Avatar
why do OTR trucks not have placards on the trucks. My Peterbilt had 135 gallon tanks.
this tank outer dimensions are 24x24x48, baffled twice inside the tank and has 1/8" diamond plate. outer dimensions are 120 gallon so fingering 119 or so. DOT can kissssss meeeeee tail
