4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Ticking noise oil pan
Old Mar 25, 2012 | 02:51 PM
Busboy's Avatar
I have looked for the thread but was unable to find it. There was a youtube link and it was just unbelievable. It is quite common and most often it's the belt but has also been the dampener. The spark is very noticeable and is from the dampener to the oil pan and makes a ticking noise. If that's it you will see the spark by laying under the truck and looking up.
Old Mar 26, 2012 | 06:42 PM
howe719's Avatar
i will just again but i dont think its a spark because i would most likely get shocked if i touch the oil pan and when i touch the pan i can feel a tapping noise with my hand and hear it.
I am going to do a video and upload it and see if anyone can tell what the heck it is.
thanks
Old Mar 27, 2012 | 04:46 PM
howe719's Avatar
the video is attached on the link. You can hear the tap start at 53 seconds in the video. It starts around 1500 rpm and from the video you can hear it get faster and faster as the rpm climb. In the video right around 2 minute mark you can hear it and as i speed up is sounds like it gets faster and faster.
Any thoughts?? no one seems to have a clue what it is.
http://www.youtube.com/watch?v=KrCTr...ature=youtu.be
Old Apr 2, 2012 | 09:45 AM
denhammkc's Avatar
Just a thought, it could be the oil pump. I tried installing an amsoil dual bypass on the frame rail and the vibration in the lines and housing for the filter created a tapping sound that increased as the rpms of the engine (and oil pump) increased. I switched to am amsoil BMK-21 and it does not make the sound/vibration. The 25 took the oil from the filter to the housing and the full volume of oil at full pump pressure is what was doing it. You could just be hearing the pump vibration in the oil pan, I can hear mine and it is almost exactly like what I heard from the bypass.
Good Luck
Old Apr 6, 2012 | 02:55 AM
Stargeezer's Avatar
Could it be the pump "timing"? I have a definite tapping near it and the service tech told me there was a fix, but since it was not considered a warranty repair I would have to pay to do it and he could not guaranty it would fix it.
Seems there can be at tap at the pump if the pump inpulse is out of sync with the motor ignition cycle. I may have this all wrong since it was passed to me third hand
Old Apr 15, 2012 | 06:19 PM
howe719's Avatar
Should i be worried about this issue? I dont want anything to happen to my motor that would cause major damage!! Any ideas on what i should do? thanks
1985cucv
Apr 11, 2010 10:42 AM
tex23455
Jul 25, 2007 02:31 AM
bostongsx
Sep 25, 2006 11:25 PM
Mostwanted
28
Nov 3, 2005 06:18 PM
yrusoslow2
Feb 9, 2004 12:31 AM
