4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
low sulphur fuel reqmnt
Old Jan 12, 2010 | 10:44 AM
edc's Avatar
edc
Question low sulphur fuel reqmnt
I notice on the dash of the 2010 trucks I have been looking at there is a warning that says "use low sulphur fuel only" or something like that. Is that something I will have to be aware of as I drive around the US? Are there areas in the US including Alaska that sell (at service stations for motor vehicles) diesel fuel that is not what Dodge/Cummins recommends? And if you used something other than this low sulphur diesel fuel is it just an emissions issue or does something get screwed up in the engine? The dealer said not to worry about it as all fuel available everywhere meets the spec -- I wonder if that was true why they would waste money on the warning label. Ed
Old Jan 12, 2010 | 12:33 PM
ssandlin's Avatar
Starting with the introduction of the 6.7L engine in the model 07.5 and later years trucks, Ultra Low Sulfur Diesel (ULSD), which is 15ppm or less, is required in these engines. The 5.9L engines can run either Low Sulfur Diesel (LSD), which is 500ppm or less) or ULSD.
And yes, you should check the stickers on every pump to be sure you use ULSD in the 6.7L engines. Most all stations now have ULSD, but there are still some that sell LSD, at least here in central Texas. I know this because those stations are where I buy fuel for my 5.9L.
Check the 6.7L forums, where you can find more info. Hope this helps.
Old Jan 12, 2010 | 12:36 PM
Totallyrad's Avatar
IIRC, (LSD) Low Sulfur Diesel is still legal until mid 2010, after that the only thing you can get is (ULSD) Ultra Low Sulfur Diesel. The switch began a while back so you'll be fine, no worries.
Old Jan 12, 2010 | 01:00 PM
edc's Avatar
edc
thanks, what are the consequences of non-intential use of the LSD in the later engines? More DPF regens (or whatever it is called) or actual damage?
Old Jan 12, 2010 | 04:01 PM
Totallyrad's Avatar
I believe you'll likely have issues with the DPF and EGR becoming clogged/restricted. That in itself can cause you unnecessary trips to the dealer and the cost of repairs would most probably fall squarely on your shoulders for using an improper fuel.
edc
Apr 2, 2010 05:55 AM
teqmod
Jun 24, 2007 10:40 PM
Rocket95
Sep 17, 2006 05:44 PM
Jerry Cowing
34
Aug 26, 2006 09:41 PM
