4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
G56 whine
Old Mar 24, 2012 | 11:35 AM
TIM RYDEN's Avatar
G56 whine
I have a high pitch whine in 6th running 70-73 mph. If I push the shifter to the right it goes away. It seems as if their is a lot of pressure pushing the lever to the left. Has been like this since I bought it. I has not seemed like a big deal. Just wondering if their is a simple fix.
Old Mar 24, 2012 | 06:13 PM
Flatlander's Avatar
I don't have a fix, but have noticed the same thing. Not too often I drive at that speed though, just on vacations.
Old Mar 24, 2012 | 08:31 PM
TIM RYDEN's Avatar
As long as it doesn't blow apart and send the shifter through the cab I'm ok with it.
Old Mar 25, 2012 | 08:33 AM
Grand Geek's Avatar
Next time your driving your rig listen in each gear at the same rpm as what you would be at in 6th at 73 mph.. see if you have the sound.. My truck does it also, I notice it in each gear around 2300 rpm.. I never get to that rpm in 6th but i imagine its there if i was to get there.
Old Mar 26, 2012 | 05:20 AM
Blake Clark's Avatar
Mine had a slight whine in it stock. I went away after the trans broke in, around 18k or so.
Now with the South Bend, deletes, 5" TBE, etc... You cant hear nothing out of it...
Old Mar 27, 2012 | 09:19 AM
Grand Geek's Avatar
Blake how do you like the south bend clutch? I'm at 35000 ish miles it still whines like a wife tied to her stove..
Old Mar 27, 2012 | 12:32 PM
marathon's Avatar
Add a Qt
Try adding an extra quart of transmission fluid through the shifter. Mine did exactly the same thing plus being extra noisey at start up because it's parked uphill. One quart and everything quiets down.
Do a search. There are a couple of threads on it.
Old Mar 27, 2012 | 04:27 PM
Done did. My is happily chewing on 7 quarts of Gorilla Juice.
Old Mar 27, 2012 | 04:28 PM
Love it. Little grabby at times, such as low speed turning in a parking lot and such. But it sure puts the power to the back wheels. It was quite a bit louder with the DMF gone, but the Gorilla Juice took care of that.
Old Mar 28, 2012 | 10:55 PM
TIM RYDEN's Avatar
Added a quart of trans fluid. It made a difference. I think Blake is also right. It needs a little time to break in.
marathon
Jan 17, 2011 08:28 AM
adamrc
Apr 3, 2007 11:24 AM
crankbait
Feb 25, 2003 10:07 PM
mymaur
Dec 23, 2002 09:57 PM
