4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
2012 4x4 front end thud/pop???
Old 10-06-2016, 10:05 PM
krawler-N-tow's Avatar
2012 4x4, 60k miles. Just started this yesterday. When turning, usually slowly, I get a loud thud or pop from the front end. It doesn't do this all the time. I've visually checked everything while I had someone turning the steering wheel and didn't see anything. It seems like its coming from the drivers side. Its loud enough it has me very concerned. I haven't checked the BJ's yet but it doesn't make sense to me for it to be that.
I can see a bit of movement in the track bar at the frame but I think that's just the bushing giving.
Any ideas before I have to somehow make time to get it to a shop?
Old 10-10-2016, 11:26 PM
lovinCTD59's Avatar
I would get the front end off the ground and check ball joints, U joints and wheel bearing assemblies. Also check around the steering gear box. I had one is the shop last month with loose bolts holding the gear box to the frame.
Old 12-24-2017, 07:31 PM
Dojman's Avatar
I had a right side u joint at replaced at around your mileage. It was popping and binding when turning sharply. I couldn't shake it by hand with it on the ground. It was apparent when the shop jacked the front end up and cut the wheels while spinning the wheel.
Old 12-25-2017, 05:36 AM
ptm600's Avatar
Axle joint. Look far any sign of rust dust around the bearing caps. One of them will probably have some.
dieselJon
11-21-2007 05:53 PM
973604x4
09-04-2007 08:18 PM
V.R.Wheeler
08-04-2007 01:00 PM
Dave88LX
25
06-15-2007 08:12 AM
Dynocon
02-26-2006 10:21 AM
Quick Reply: 2012 4x4 front end thud/pop???
