winter fuel
Old Nov 28, 2003 | 08:34 PM
mitchkim's Avatar
winter fuel
does the winter fuel have a lower or higher centene rating than summer fuel ???
Old Nov 28, 2003 | 10:59 PM
Lightman's Avatar
Re:winter fuel
The cetane rating could be the same, but typically winterized fuel has a higher percentage of diesel #1 or kerosene blended in with it. Diesel #1 and kerosene have less btu's (energy) per gallon, so overall mpg decreases proportionately with blended fuel. Best to find unblended #2 and use anti-gel additives IMO
Old Nov 29, 2003 | 10:29 AM
cp's Avatar
cp
Re:winter fuel
Blended fuel should be higher cetane. Higher cetane aids in cold starting, not much else.
Old Nov 29, 2003 | 04:57 PM
Lightman's Avatar
Re:winter fuel
cp, why do you think blended fuel has higher cetane?
Old Nov 29, 2003 | 05:07 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:winter fuel
Fuel pumps around here are labeled with minimum cetane ratings.
If (Huge IF) they are labeled correctly : there should be no difference.
However, #1 diesel has less lubricity.
#1 also gells at a lower temp.
Old Nov 29, 2003 | 05:49 PM
mitchkim's Avatar
Re:winter fuel
does kerosene have a centene rating
if it is lower than diesel#2 than mixing kerosene with #2 would lower the rating would it not
Old Nov 29, 2003 | 06:16 PM
Lightman's Avatar
Re:winter fuel
It doesn't matter one way or the other for the most part. The mpg loss will be there no matter what due to lower btu's of the kerosene/#1. Especially during times of winter blended fuel, using a fuel additive is recommended. As posted above, blended fuel has less lubricity, and the additives will help to lower the gel point and boost cetane.
Old Nov 30, 2003 | 09:02 AM
cp's Avatar
cp
Re:winter fuel
[quote author=Lightman link=board=17;threadid=22991;start=0#msg215743 date=1070146662]
[/quote]
I don't know. I always thought that the higher fractions had higher cetane, but I can't find any reference to support my statement, so I'd better retract it. In fact, the only thing I could find states that #1 may be a couple of points lower in cetane rating than #2, not higher as I said.
Good catch.
Old Nov 30, 2003 | 10:21 AM
Lightman's Avatar
Re:winter fuel
WEll cp you're partially right...the 'higher fraction' does have higher cetane. #2 is generally has more btu's and cetane, however it's the highest percentage of the mix. It has to get pretty darn cold before that mix hits 50/50. Perhaps you were thinking about offroad fuel, which typically has more cetane along with more sulfur..
Tedonlin150
46
Nov 21, 2011 10:45 AM
snowmanx
Nov 9, 2007 05:34 PM
dieselnewbie
13
Mar 19, 2004 10:08 PM
cmckinney
14
Mar 4, 2004 09:51 AM
wood_n_soldier
Dec 16, 2003 06:18 PM
