Upgraded steering
Old Nov 1, 2009 | 03:11 PM
  #406
Raspy's Avatar
Originally Posted by Fisherguy
Got a part number for the kit? I'm not having any luck finding it.
Please check my previous post. There is no "kit". You just order the '08 linkage and you order the '08 pitman arm.
Old Nov 1, 2009 | 06:14 PM
  #407
turbochabot1's Avatar
52122362 AE steering kit
52122370 AA steering damper
CBFAH362 draglink inner joint package
CBCZH461 pitman arm
These are the part numbers for what was replaced on my truck under the steering recall.
Old Nov 1, 2009 | 06:21 PM
  #408
Fisherguy's Avatar
Thanks Turbo, price at that site is 241.25
(and the siye doesn't work with Firefox)
https://www.dodgetruckparts.net/oem-dodge-parts.html
Old Nov 2, 2009 | 08:04 AM
  #409
WildBill79's Avatar
[QUOTE=bansh-eman;2618299]Ok so I want to upgrade my steering as well. I am going to be putting a 4.5in lift on there that comes with a differant pitman. With the lift the stud should not hit the rod right?
QUOTE]
If you are using a drop pitman arm then you will not need the new pitman arm because the stud is facing up.
Old Nov 2, 2009 | 08:59 AM
  #410
bansh-eman's Avatar
Ok so all I need to order is the 52122362 AE right? You reuse your stock bolts and nuts? And I will be doing aftermarket Stabilizer.
Old Nov 2, 2009 | 07:45 PM
  #411
bansh-eman's Avatar
After seeing that these don't have any zerks, and the fact that I haven't had any issues with my stocker. I am keeping what I got. I can't see switching to somethig that you can't grease. This seems to be the same junk as the stock ball joints.
Old Nov 2, 2009 | 08:10 PM
  #412
Fisherguy's Avatar
Wow, I thought they were greaseable, went back in this thread and looked at the pictures, no zerks, that sucks...
Old Nov 7, 2009 | 11:13 AM
  #413
Raspy's Avatar
It does suck.
I wonder if we can use one of those needle grease guns, as someone suggested, and grease them adequately through the rubber boot?
It's still worth it to me because the linkage is so much beefier and a better design too.
Old Nov 7, 2009 | 12:44 PM
  #414
lucey's Avatar
I'm curious if anyone in Canada has had this work done on warranty. I have a 160,000km warranty bumper to bumper on my 2004. Anyone ?
Old Nov 7, 2009 | 03:08 PM
  #415
Mine was covered under my extended warranty. I did have a tie rod end going so they replaced with the new steering.
Old Nov 7, 2009 | 05:17 PM
  #416
Danderson's Avatar
Source Automotive offers the setup w/zerks for a reasonable price. The new setup is much beefier and the toe-in stays constant while cycling.
Old Nov 7, 2009 | 06:50 PM
  #417
bansh-eman's Avatar
I looked at the one they have listed and it doesnt say anything about added zerks.
Link
Old Nov 8, 2009 | 05:41 PM
  #418
wiskeyVI's Avatar
If I recall, somebody on the DTR put thier own zerks in.
Old Nov 8, 2009 | 07:27 PM
  #419
trik396's Avatar
Link
I bought mine from Source and they have the zerks. Just greased them yesterday as a matter of fact.
Old Nov 17, 2009 | 09:52 AM
  #420
justin allan's Avatar
I have been reading this thred for Hours. At any rate I have 197k with a 4.5 inch lift steering is loose as a goose. So should I get my steering setup from source automotive? Trac bar is loose to. I need to do this soon.
Thanks
Justin.
