Upgraded steering
Old Jun 14, 2009 | 08:56 PM
  #391
donhov's Avatar
Took my early 07 in last week for the fix at 28,000 miles and got a call the upper & lower balljoints were toast. All was replaced "under Warranty" including pitman arm and stabilizer. Looks good and steering is very tight, didn't notice a problem but can tell it's better now. No problems, Hillsdale Dodge in Hillsdale Mi.
Old Jul 1, 2009 | 12:31 PM
  #392
finndogg54's Avatar
Im going to put on all the AE parts this weekend. Any do's and dont's. Do I jack it up on the frame and let the suspension come down? or leave it on the ground? its probably one of those things where you mess with it to get the pressure of the links im not sure any help would be great. i do have all the tools for the job though.
Old Jul 6, 2009 | 12:51 PM
  #393
finndogg54's Avatar
Nevermind. got r done! no issues
Old Jul 6, 2009 | 04:41 PM
  #394
Pull Ya's Avatar
donhov,
I'm glad you got your ball joints replaced under warranty--the down side is that they replaced them with same OEM junk they have been using for years.
Jay
Old Oct 31, 2009 | 07:01 PM
  #395
Airdocdodge's Avatar
HEY GUYS just bought the new steering kit it was 280.00 with shipping. I need help clearing somthing up on the install. On page one of this link on the steering arm the tie rod end is facing down. Then on link page 21 it shows the tie rod end on the steering arm facing up can someone clear this up or does it not matter. When i took the old one down the tie rod on the steering arm was facing down. Please help i'm doing the install as we speek.
Old Oct 31, 2009 | 07:05 PM
  #396
Matt400's Avatar
Only goes on one way due to the taper in the pitman arm. Nut goes down.
Did you get another Pitman arm with it?
Old Oct 31, 2009 | 07:07 PM
  #397
wiskeyVI's Avatar
AirDoc
Who'd you go thru for the kit?
Old Oct 31, 2009 | 07:09 PM
  #398
BroncoAZ's Avatar
Originally Posted by Ace
I believe the shop's tech who showed me the play in the joints with the truck up on their alignment rack. I don't believe the dealer who won't even let me go in the work bay area. Oh, and you can tell just by looking at it in this pic, not to mention the RF tire was wearing on the outside:
As a dealership safety consultant I can understand their position. Most garage liability insurance policies mandate that customers are not allowed in the shop. That being said I agree with you that I want to go see the problem first hand.
Old Oct 31, 2009 | 07:21 PM
  #399
I bought it on line at dodgetruckparts.net 271.20 to be exact. Thanks Matt for the reply ididn't by a new pittmen arm so i will hook it up the way it came down.
Old Oct 31, 2009 | 07:42 PM
  #400
Matt400's Avatar
I would get the newer pitman arm too, under full suspension compression the stud on the tie rod end at the pitman arm could contact the steering cross bar.
Here is a before and after of the different pitman arm-
Old Oct 31, 2009 | 08:05 PM
  #401
Were do you get the newer pitmen arm and with all this DW GOING AROUND wold this change the geometry of the suspension.
Old Oct 31, 2009 | 09:08 PM
  #402
Raspy's Avatar
The new pitman arm is a must, not really an option because the stud does hit the tie rod. And no, the new pitman arm does not change the geometry and affect wobble.
Since this is not a "kit" people keep thinking they don't need the pitman arm, but they do. It's too bad it is not noted in the parts book that it must be used on older trucks with the new linkage.
Old Oct 31, 2009 | 11:10 PM
  #403
Fisherguy's Avatar
Got a part number for the kit? I'm not having any luck finding it.
Old Oct 31, 2009 | 11:34 PM
  #404
Matt400's Avatar
Just use an 09 Pitman arm.
Old Nov 1, 2009 | 02:49 PM
  #405
bansh-eman's Avatar
Ok so I want to upgrade my steering as well. I am going to be putting a 4.5in lift on there that comes with a differant pitman. With the lift the stud should not hit the rod right?
Also the stabilizer on my truck right now will not work on this setup right? What stabilizer are you guys getting? I cant see my self buying another junk OEM for that much. If I was to buy an after market Ineed to buy one for an "08" now to fit it right?
