Upgraded steering
Old Mar 12, 2010 | 05:38 PM
  #436
Mopardik's Avatar
What a great thread this is, although it is waaay long! I just ordered my setup with the pitman arm. I did not order the stabilizer, though. I have a brand new Bilstein one that I would like to re-use. I realize the difference in the mounting system, but a guy earlier in the thread said he reused his with some eye bushings for it. I sent him a pm, but I was wondering if anyone else has done this? I looked at mine, and the stud is just inside and eyelet end anyway. Should be a simple press out affair, install some bushings, and voila, no need to buy a new $100+ stabilizer! I just need to get the right bushings. Any ideas?
Old Mar 12, 2010 | 05:58 PM
  #437
John_P's Avatar
Mopardik:
Thanks for your nice comments about this thread. The steering problems on our Dodge CTD Trucks is probably one of the most asked questions on this website. We have alot of DTR Members (including myself) that have experienced problems with the steering on our trucks and our Members have really "steeped up" in this thread to provide ALOT of information and solutions to the problems.
On your question about the eye bushings, I can't help you there as I didn't do that on my truck, but the other Members will chime in here I am sure.
Thanks again.
John_P
Old Mar 12, 2010 | 06:28 PM
  #438
Mopardik's Avatar
Thanks, John. OK, here is the info I have garnered thus far. I talked to a nice guy at Bilstein, and found out the id of the stud end eyelet on my 5100 series stabilizer is 28mm. So now all I need to know is the size of the stud on the steering kit, and I can order the bushings. Hopefully this will work out nicely, and be an option for others to not have to buy the stabilizer to make this setup work.
Old Mar 16, 2010 | 12:49 PM
  #439
Mopardik's Avatar
Still trying to find the size (dia.) of the stud that mounts the stabilizer to the attachment bracket. Any help appreciated.
Old Mar 17, 2010 | 08:33 PM
  #440
03CTDCO's Avatar
trik396
The upgrade kit from Source, does this come with replacement hardware AND did you replace your pitman arm ?
Isn't that part needed with the new set up ?
Thanks
Old Mar 24, 2010 | 01:30 PM
  #441
Mopardik's Avatar
Just an update on this. You can install the assy. without purchasing the new damper. I pressed out the bushing and stud on mine, and installed a bushing and sleeve from energysuspensionparts.com (#99105 -$7.60), and it worked like a charm! Mine was a Bilstein damper, but it's identical to the stock one in this regard. So if yours is in good condition or an aftermarket (single), you can still use it and save about $90!
Old Jun 6, 2010 | 12:27 PM
  #442
quicksilvr's Avatar
Would this be covered by the 7/70 powertrain warr.?
Old Jun 18, 2010 | 07:49 PM
  #443
John_P's Avatar
quicksilvr:
Sorry for the delay in answering your question Sir.
Dodge did cover all the front end work on my truck under warranty.
John_P
Old Jun 18, 2010 | 08:44 PM
  #444
Pull Ya's Avatar
There have been some problems with the new steering kits. It has been reported by a few people that they have had the tie rod end bolt snap off. Dodge said they do not make the individual tie rod ends and you have to replace the whole kit again.
Jay
Old Jun 18, 2010 | 08:46 PM
  #445
Fisherguy's Avatar
I wonder if that's only with the original upgrade the new one replaces?
Old Jun 18, 2010 | 09:07 PM
  #446
Danderson's Avatar
Some TDR members have posted breakage at low speed no less with the "AE" upgrades.
Old Jun 18, 2010 | 10:41 PM
  #447
Fisherguy's Avatar
Ae?
Old Jun 19, 2010 | 10:11 AM
  #448
bob4x4's Avatar
The steering linkage is not covered under the powertrain warranty.The max care service contract does.
Old Jun 19, 2010 | 10:12 AM
  #449
bob4x4's Avatar
Originally Posted by Fisherguy
Ae?
Suffix of part number.The latest is up to AF IRRC
Old Jun 19, 2010 | 11:33 AM
  #450
Fisherguy's Avatar
Wow, if the "new & improved" stuff is breaking what's the alternative? I haven't heard that but haven't been on the forums as much lately.
Hate to think we need to go to the Thuren setup that won't even work with some wheels. I don't like have to drill to put it on, no going back...
