Unloaded weight of 3500 crew, LWB
Old Sep 13, 2004 | 08:49 AM
Hedgehog's Avatar
I am looking for the unloaded vehicle weight of a 2004.5 Dodge3500 4X4, crewcab, longbed, cummins600, single rear wheel. I am just trying to figure out if the single rear wheel will have enough payload capacity for my fifthwheel camper.
Old Sep 13, 2004 | 10:53 AM
jk1364's Avatar
Hedgehog,
You need to weigh your own truck. They all weigh different because of the options. About 5 to 10 bucks and you will know what your trucks weight is. It needs to be full of fuel you ,passengers, and all the stuff you would take with you on a trip then weigh your truck and that will tell you what pin weight you can put on you truck. Only way to do it.
John
Old Sep 13, 2004 | 11:33 AM
CTD NUT's Avatar
Hedghog:
Ballpark around the 7000 lb mark. Depending on what you carry with you + passengers, gear , fuel - could be + 500 - 1000lbs easy. Not much left over if you have a heavy pin weight but lots of guys do it - but IMO a dually is always better for a 5ver.
Old Sep 13, 2004 | 11:40 AM
Don-T's Avatar
I have a REGULAR cab 4x4 dually and with the fifth wheel hitch and a full load of fuel (85 gal) and no one in it the cat scales show 7950 lbs.
Old Sep 13, 2004 | 06:00 PM
Dodgezilla's Avatar
My 03 with a full tank of fuel and 200lb(est) toolbox weighed in at 7400lb. I'd say that you're around 7200lbs but the only way to know for sure is to put it on a scale...
Old Sep 13, 2004 | 07:05 PM
USMC64-70's Avatar
Just weighed my 2004.5 3500 SRW, 4x2, full tank, no passengers = 7,060 lbs. Includes my 5th wheel hitch.
Old Sep 13, 2004 | 08:50 PM
MOPE540's Avatar
have yet to weigh it...but the title says 7930 lbs
Old Sep 13, 2004 | 09:12 PM
jk1364's Avatar
Hedgehog,
There you go pick a weight that fits you. But you will never know what your real weight is unless you weigh your own truck.
Done that.
John
Old Sep 13, 2004 | 10:27 PM
Scotty's Avatar
Top's Younger Twin
8640 pounds with the stereo, hitch rails, 150 pounds of rope in the bed, slip tank, empty and the Road Armor bumpers.
I will be adding close to 300 pounds with the advanced air ride hitch and then add 462 pounds when I fill the slip tank.
Old Sep 13, 2004 | 10:53 PM
Equalizer 2's Avatar
Too many variables as stated previously. My truck with full tank, toolbox, hitch, and NO passengers is about 7800 lbs. Type of transmission, 2 wheel drive vs 4 wheel drive, everything makes a difference. If you have a State DOT scale nearby. When closed they frequently leave the scales turned on so people can use them.
Old Sep 13, 2004 | 11:17 PM
Big Bob's Avatar
Ghost Rider is 8860 lbs, with a total of 94 gallons of fuel and me (350#) setting in it.
Old Sep 17, 2004 | 01:11 AM
Bubba_CTD's Avatar
From: From Texas; Staioned in WA; Transplanted to AZ
****, I had a half tank with about 100 lbs in a toolbox and without me in it, it was 7080.
Old Sep 18, 2004 | 09:25 AM
bronco351's Avatar
my 04 2500 QC auto weighs 7800 with a full tank and no crap in the bed. Alot heavier that I ever expected..
gaylejoe
Dec 7, 2010 08:25 PM
Banzai Bob
Mar 3, 2009 01:22 AM
NDanecker
Sep 5, 2008 10:57 PM
Ramasaur
15
May 21, 2005 12:12 PM
faster_than_ford
Aug 26, 2004 11:36 AM
