u joint in rear drive shaft
Old Aug 1, 2012 | 11:22 AM
rdr140's Avatar
what brand of u joints u running in the reatr shaft on a 03 shorty 4x4 . time for some new ones thanks robbie
Old Aug 1, 2012 | 12:34 PM
Shorts's Avatar
Spicers are a good choice.
Old Aug 1, 2012 | 02:34 PM
klx650a2's Avatar
I have greaseable Spicers in the front of my truck and love them. When I had to replace my stock rears, Spicer did not have them available yet.
Old Aug 2, 2012 | 08:22 AM
surfram's Avatar
I just installed Precision 330A greaseable u-joints on my rear driveshaft last week. I believe your 6-speed will take 351A precisions on the rear driveshaft. Here are some pics of the original u-joints:
Old Aug 3, 2012 | 10:14 PM
rdr140's Avatar
thanks surfram. going to get the per at napa 33 bucks i think thats what they said it was 351a .thanks rob
Old Aug 4, 2012 | 12:12 AM
FWIW,
The only place I could find them "made in the USA" was from napa....
Go figure...
Old Aug 4, 2012 | 08:41 AM
Asher's Avatar
I hope you have better luck with yours then I did... I could not find a u-joint to actually fit my shafts... Everyone of them I tried was about .100" to long and would not let me put the retaining clips in without placing a extreme amount of pressure on the joint and ears. Something that should have taken an hour, took me more then a day running around to autoparts stores and measuring what they had in stock. I can not see how to make the "called for" joints work without grinding them down alittle bit on the ends, but thats where you get into a "out of balance" issue...
Long story short, I forced the joints in but they are extremely tight, took alot of pressure from my hydro press. I now have a slight viberation at about 70mph... I am to the point dropping the cash and just having a driveshaft shop redo it and balance it out..
Before its asked, I put u-joints in my jeeps and other vehicles all the time. So it's not a lack of experience thing... It's like the retaining groves where machined to far into the ears or not wide enough...
Old Aug 4, 2012 | 11:58 AM
rdr140's Avatar
thank asher i let every one know how it turnns out . going to my friends meching shop to do it. should not take long and i'll have every mechine known to man to use if i have problems.
Old Aug 5, 2012 | 07:09 AM
mini14's Avatar
asher, the only ones that will truly fit are the aam joint, i knew that when replacing mine, i used spicer 160x they also r .100 too big, the clips are a little bowed out but have been in for over a year now with no issues, all you have to do is grind or belt sand the caps down slightly, for a perfect fit. I allways mark a line down the shaft so everything goes out and in the way it was originally installed
Old Aug 5, 2012 | 09:18 AM
surfram's Avatar
The precision 330A and 351A are designed for AAM driveshafts. Mine fit perfectly.
Old Aug 9, 2012 | 11:07 AM
slacker 24/7's Avatar
i just put in a pair of sealed spicers 1410x using the std. hammer and sockets routine and they fit perfect.. dunno
Chip
Dec 6, 2009 01:34 PM
JGP, JR.
Jul 2, 2008 02:04 PM
jj3500
Jun 28, 2008 07:36 AM
slowwheelin
Oct 1, 2007 08:16 PM
