Squeak in Drive Shaft, U-Joint??
Old Jul 2, 2008 | 08:26 AM
JGP, JR.'s Avatar
My father in law has a 05 CTD QC, SWB............been noticing a squeaking sound coming from drive shaft, universal joint area. Sounds just like a squeaky bed spring when he starts off. Apparently only squeaking when the drive shaft gets to a certain point, hence the "bed spring" sound. Local mechanic told him it was if he had been in deep mud from a river bottom, beach sand, etc. He has not had the truck in an area such as this, although he is second owner. Anyone had this problem...........?? Any suggestions/help in diagnosis appreciated.
Old Jul 2, 2008 | 10:39 AM
matego's Avatar
madhat's monkey boy...
Squeaky joints are usually totally dry of grease. If you really want to know for sure, run the truck on jack stands and watch the shaft. I had a joint that was tight when wiggling/moving by hand but was easily detected when run on jack stands. If they have never been replaced yet you might want to do it for preventative maintenance, the factory ones are junk.
Old Jul 2, 2008 | 12:30 PM
Mr.Blonde's Avatar
I had the same problem with my '03. I took in into the dealership and they ended up replacing the whole two piece drive shaft. It ended up only costing $100 because it was covered under the 7/70 powertrain. I don’t drive the truck much and I had the shafts replaced in the fall of ’07 with only 38k miles on the vehicle.
Old Jul 2, 2008 | 02:04 PM
JGP, JR.'s Avatar
Alright...........Thanks. By the time I had started the thread he had already taken to local dealer and found out the joint needed replacing............and you were right............$100.
Thanks again
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
ytodd
Nov 2, 2007 09:57 AM
FDC
Jul 16, 2007 12:51 PM
gman07
May 9, 2007 06:03 AM
