Replacing rear calipers... what else should be replaced?
Old May 21, 2011 | 08:54 AM
PapaPerk's Avatar
Hello,
I'm replacing both rear calipers on my 04.5 truck. Left rear is seized at slides.
So with that being said what else should I replace while I have it apart? I will be replacing the pads of course. I believe I'm also supposed to replace the washers at the brake line x brake caliper banjo fitting. Should the bolt also be replaced?
I'm doing this type of work on this truck for the first time and need some advice before I start. I do all types of machine work... but never have worked on brakes. LOL!
Thanks for any advice.
Old May 21, 2011 | 09:15 AM
6spd05Dually's Avatar
Originally Posted by PapaPerk
Hello,
Papa, how many miles are on the brakes and rotors? In addition, do you drive highway mostly or more city driving?
Old May 21, 2011 | 10:33 AM
NoSparkplugs's Avatar
I had this happen to me last fall. Came home from work, stopped at the diesel pump to fuel up and smelled something really raunchy. Then I noticed that the left rear wheel was smoking hot. I ended up replacing the caliper, pads and rotor since they were all ruined from the heat. The rotor was completely blued and I didn't want to take any chances. Replacing the brakes on these trucks is actually real simple. Only took me about an hour start to finish. Also if you replace the rotor, clean the new one off with brake clean first! The coat them in a rust inhibitor for shipping and storage purposes.
Old May 24, 2011 | 08:55 AM
KirtW's Avatar
DTR Advertiser
Brake Fluid
Go to the root of the problem and completely flush your brake fluid with new Dot 3 before you put your new parts on the truck.
If this has never been done on a truck that is 5-6 years old your brake fluid is probably around 10-20% water.
I have watched in horror many times as guys, "mechanics" mind you, will change calipers without flushing fluid. Recommended procedure is now every 1-2 years for most manufacturers.
Old May 24, 2011 | 11:36 AM
PapaPerk's Avatar
The truck has around 60K on it. The rotors are in good shape.
Draining the brake fluid sounds like a good idea. Of course to do that I'll have to take the front apart too. Maybe new calipers all the way around! LOL
dbossdiesel
Sep 30, 2012 05:29 AM
PapaPerk
May 21, 2011 08:50 AM
bobsallyh
Apr 2, 2009 11:38 PM
shortround
Feb 19, 2008 10:14 PM
digbog
Sep 18, 2007 03:30 PM
