Removing rear spacers
Old May 23, 2004 | 09:52 AM
Tony T.'s Avatar
Thumbs up Removing rear spacers
I could not find if this has been covered in the search fourm, but I recently removed the rear spacers on my 03 3500 SRW CTD. This lowered the rear 1.25" an gave a more level look to the truck. I had considered raising the front with spacers, or new coils, but my truck tracks so good now I was afraid to mess with the front end. The rear will still be 1/2" taller in the rear with the spacers removed, but still gives the truck a level look. This mod took only a little over a hour with the use of a friends shop, floor jacks, an impact wrench. Good thing is there are "no" parts to purchase an it is totally reverseable with in about the same time frame. I did obtain the info from another website for this mod. Also plan in the future on getting a 5th wheel trailer an I believe this will help with clearence between the top bed rail an the front overhang of the 5th wheel.
Old May 23, 2004 | 10:23 AM
Patrick Campbell's Avatar
what are the spacers, the extra plates between the leaf spring and the spring pirch?
Old May 23, 2004 | 12:36 PM
Nitro71455's Avatar
Yep... those are them. There is 2 per side. I've removed mine as well. No ill effects came from it at all.
Old May 23, 2004 | 01:42 PM
danram11's Avatar
Thumbs up
Did the same, surprising that an inch and a quarter will make a difference in appearance, but it does look more level.
Old May 23, 2004 | 06:29 PM
12rBluByU's Avatar
did you remove them all together or did you swap them to the top??
Old May 23, 2004 | 06:49 PM
RickE's Avatar
Check out this site: http://www.klenger.net/dodge/lowerin...d/slide01.html
Also, wetspirit has detailed instructions posted in January.
I moved the spacers to the top and reused the existing bolts. The ends of the bolts that go thru the spring pack are a little deformed and might need to be filed or cut off.
boaterman
Apr 14, 2008 07:32 PM
turbo dreams
Oct 13, 2007 12:50 PM
beardedone
Feb 7, 2006 05:15 PM
apatche
13
Jan 30, 2006 09:08 AM
tweeter
Nov 5, 2005 07:51 AM
