Remote start?
Old Nov 26, 2005 | 10:29 PM
genros's Avatar
Remote start?
Do any of you all have a remote start?
Does it have a wamr up or something for the "glow plugs" before it actually starts the truck?
tricky install?
how much$$$?
Old Nov 26, 2005 | 10:40 PM
Geico266's Avatar
tricky install?
how much$$$?
No glow plugs here. We have grid heaters, but to answer your questions remote starters are no problem. I have one my 2nd gen. They just wait until the "wait to start" light goes off then it starts.
Old Nov 26, 2005 | 11:16 PM
tweeter's Avatar
I had the MOPAR remote starter installed by my dealer, it was a little more expensive than the aftermarket, but it is covered for the full term of my warranty, works awesome. Found 1 little qwirk with it that took a few times to figure out, when the low fuel lamp is on, it won't start the truck.
Old Nov 26, 2005 | 11:41 PM
genros's Avatar
how much was the mopar one installed?
ANy aftermarket ones i should look for otherwise
Old Nov 26, 2005 | 11:53 PM
tweeter's Avatar
It was around $600.00 complete with tax, but thats in Canadian $$$$$
Don't know what to recommend for aftermarket, I was more comfortable having my dealer do it.
Old Nov 27, 2005 | 07:27 AM
bbhzx12's Avatar
If you go with the Mopar the install is the easiest so if your not an experianced installer it's the best way to go. I believe the dealerships are around $500 installed. The aftermarket systems start the truck the same, and often have more options you can get like keyless entry which isn't available from Mopar without carrying 2 remotes. If you go aftermarket I'd reccommend a DEI system, they have alot of brands but they are the best systems I've installed (I've done a few!) they make Viper, Python, Automate, and tons of others. Many of the newer DEI systems also have a built in turbo timer, if the truck is hot you hit the button on the remote take the key out and the truck stays running for 1,3, or 5 minutes to cool off.
Old Nov 28, 2005 | 05:45 PM
underwoodtransp's Avatar
I have a compustar one.. I believe it is also made by dei. It was a pain in the you know what to install it took the professional installer 8 hours to get it right. It was $550. installed. two way remote so that you know when it is running and also has the turbo timer. I just hit the e-brake pedal and turn the key off. It runs for 3 mins then shuts down. love it...
Undertaker
Oct 26, 2009 03:02 PM
TWK
Nov 16, 2003 10:26 AM
I PASS GAS
Nov 6, 2003 10:25 AM
billuem
Oct 6, 2003 06:05 PM
fanofthewolf
Apr 19, 2003 06:30 AM
