Rattling??? Any ideas??
Old Jan 10, 2010 | 05:39 PM
yamarx1's Avatar
I just recently been hearing this rattle, sounds like the bed is rattling off when I go over some bumps then other times sounds like its under the cab any ideas?
Old Jan 10, 2010 | 06:39 PM
mitternocht's Avatar
Could be exhaust or what have you, check your spare tire too.
Old Jan 10, 2010 | 07:37 PM
charger7022's Avatar
i have been having the same problem but cant pin point it i just replaced the ball joints on the pass. side the upper was loose and noticed i have a bad tie rod so im going to change that to but sometimes it sounds like it is coming from the bed well se what happens
Old Jan 10, 2010 | 10:27 PM
MichRedneck's Avatar
Its a diesel it susposed to rattle...
Oh sorry its a 3rd gen
I didnt think they knew how to rattle
Old Jan 10, 2010 | 10:44 PM
BigIron70's Avatar
Cummins Guru
Do you have running boards? I had mine hitting the body mounts and making noise.
Old Jan 11, 2010 | 07:11 AM
yamarx1's Avatar
I had checked exhaust and step rails but not the spare tire so I'll do that tonight when I get home from work.
Old Jan 11, 2010 | 12:50 PM
Lost Lake's Avatar
Roll the truck over on its roof and gently tap with a rubber mallet wrapped with a towel (Quiets the blow and keeps the mallet from scratching your paint) looking for something that rattles.
Or you could buy a louder stereo...
Old Jan 12, 2010 | 12:23 AM
msiminoff's Avatar
I had this rattling sound that was driving me CRAZY for months ...
Turns out the jack under the passenger seat had worked its way loose (I have never used or removed it) and was vibrating in the mount.
At least in my case it was an easy fix.
Cheers
-Mark
Old Jan 12, 2010 | 08:58 AM
rogers259's Avatar
Track Bar? Might want to give that a check.
Old Jan 13, 2010 | 10:35 AM
tocayo's Avatar
My problem was the heat shield on the fuel tank. The plastic retainer clip broke off and the heat shield was hitting the driveline.
Old Jan 13, 2010 | 12:14 PM
Clane's Avatar
Same thing happened with my old 1/2 ton gasser...
Old Jan 13, 2010 | 01:26 PM
rogers259's Avatar
glad you got the problem resolved
Dieseldirt
Oct 3, 2006 07:16 AM
Dufrain
Apr 5, 2005 09:00 PM
jsr21
Jul 16, 2003 02:16 PM
mymaur
Jun 20, 2003 01:14 AM
MJR
Mar 16, 2003 08:26 PM
