washer fluid fuse for 2005
Old Jan 13, 2010 | 07:22 PM
trap grease's Avatar
i have a problem. i need to know witch fuse provides power to the washer fluid pump . boss,s truck is 2005 2500 4x4 4door big horn ctd . any help would be greatly appriceated .
Old Jan 13, 2010 | 07:59 PM
madhat's Avatar
Administrator/Jarhead
I believe that it is controlled by a relay, not a fuse.
Old Jan 13, 2010 | 08:16 PM
madhat's Avatar
OPERATION
The washer pump/motor unit features a small
Direct Current (DC) electric motor. The motor is connected
to the vehicle electrical system through a single
take out and two-cavity connector of the right
(except diesel engine) or left (diesel engine only)
headlamp and dash wire harness. The motor is
grounded at all times through another take out of
the right (except diesel engine) or left (diesel engine
only) headlamp and dash wire harness. On models
without the diesel engine, a single eyelet terminal
connector is secured by a nut to a ground stud
located on the right front fender inner shield in the
engine compartment. On models with a diesel engine,
an eyelet terminal connector is secured by a ground
screw to the left front fender inner shield in the
engine compartment. The motor receives battery current
on a washer pump/motor control circuit.
The washer pump/motor control circuit is energized
through a high side driver within the Front Control
Module (FCM) whenever the FCM receives an electronic
message requesting washer system operation
from the instrument cluster over the Programmable
Communications Interface (PCI) data bus. The
instrument cluster monitors a resistor multiplexed
hard wired input from the momentary washer switch
contacts within the multi-function switch on the
steering column to determine when it should issue
the electronic message requesting washer system
operation.
Washer fluid is gravity-fed from the washer reservoir
to the inlet side of the washer pump. When the
pump motor is energized, the motor spins the rotor
within the washer pump. The spinning pump rotor
pressurizes the washer fluid and forces it through
the pump outlet nipple, the washer plumbing, and
the washer nozzles onto the windshield glass.
The washer pump/motor unit may be diagnosed
using conventional diagnostic tools and methods.
However, conventional diagnostic methods may not
prove conclusive in the diagnosis of the instrument
cluster, the FCM, or the electronic message inputs to
or outputs from the instrument cluster and the FCM
that control the operation of the washer pump/motor
unit. The most reliable, efficient, and accurate means
to diagnose the washer pump/motor unit, the instrument
cluster, the FCM, or the electronic message inputs and outputs related to the washer pump/motor
unit operation requires the use of a DRBIIIt scan
tool. Refer to the appropriate diagnostic information.
bigjohn92
Nov 25, 2010 01:32 PM
Evildiesel
Nov 18, 2005 04:12 PM
Dave88LX
Jul 2, 2005 09:53 AM
MoparRiggan
31
May 21, 2005 10:03 PM
infidel
16
Jan 30, 2004 07:41 AM
