Radio Removal Question
Old Mar 7, 2008 | 10:55 AM
justagoodolboy's Avatar
I have a really dumb question, but how do I remove the radio from a 2007 MegaCab? I have the truck sold and had Best Buy install my aftermarket player, but they cannot get to the swap until next week. Is this an easy swap back to factory?
I admit I have not looked very close to see how to remove it. I wanted to start here 1st. Any help would be appreciated.
Old Mar 7, 2008 | 11:05 AM
vzdude's Avatar
DTR's 'Go to Guy'
REMOVAL
1.Disconnect and isolate the battery negative cable.2.Remove center instrument panel bezel (Refer to 23 - BODY/INSTRUMENT PANEL/INSTRUMENT PANEL CENTER BEZEL - REMOVAL) .3.Remove radio mounting fasteners.
CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
4.Disconnect the antenna cable by pulling the locking antenna connector (2) away from the radio.
5.Disconnect electrical harness connector.
Old Mar 7, 2008 | 11:08 AM
C Minus's Avatar
VZ Dude you are just on it man! You have helped a lot of folks myself included tremendously. Thanks!
Originally Posted by vzdude
REMOVAL
Old Mar 7, 2008 | 11:10 AM
vzdude's Avatar
DTR's 'Go to Guy'
I was curious if the links would work!? THEY DO!!!!
Old Mar 7, 2008 | 11:20 AM
Wow, pictures and all. Impressive!
One final dumb question and I will go back to the 1st gen forum - does the bezel pop off like all the others I have messed with or are there screws involved somewhere?
Old Mar 7, 2008 | 11:46 AM
JT's 6.7's Avatar
On the Mega Cab there are no screws holding it in place. Just pop it off. Start at the seam just below the AUX power plug.
Old Mar 7, 2008 | 01:24 PM
Thanks to Everyone. Appreciate the quick response!
Old Mar 7, 2008 | 07:33 PM
Raspy's Avatar
Hey VZ
Thanks for the info, I need to do mine too. I can't get the bezel info without a password and ID.
Can you tell me how to remove the bezel?
Thanks,
John
Old Mar 7, 2008 | 07:41 PM
vzdude's Avatar
DTR's 'Go to Guy'
REMOVAL
WARNING: On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, seat belt tensioner, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury or death.
1. Disconnect and isolate the negative battery cable.
2. If equipped, remove the floor console, (Refer to 23 - BODY/INTERIOR/FLOOR CONSOLE - REMOVAL) .
3. Remove the cup holder if equipped, (Refer to 23 - BODY/INSTRUMENT PANEL/CUP HOLDER - REMOVAL) .
4. On vehicles with a close out panel, remove the screws (3) and remove the close out panel (2).
5. Remove the screws (2).
6. Using a trim stick C-4755 or equivalent, disengage the retainer clips that secure the instrument panel center bezel (1) to the instrument panel.
7. Disconnect the wire harness connectors (4) and remove the center bezel from the vehicle.
Old Mar 7, 2008 | 07:43 PM
vzdude's Avatar
DTR's 'Go to Guy'
REMOVAL
Mini Floor Console
1. If equipped, remove the 4WD gear shift boot (Refer to 23 - BODY/INTERIOR/4WD FLOOR SHIFT BOOT - REMOVAL) .
2. If equipped with a manual transmission, remove the transmission gear shift lever extension.
3. Remove the console inserts, if equipped.
4. Remove the bolts (2) that secure the rear console (1) to the floor panel.
5. Lift up the rear of the floor console to clear the gear shift lever, if equipped.
6. Remove the bolts (2) and separate the front console (3) from the floor.
7. Separate the front clips (1) and remove the mini console.
Full Floor Console
1. Before proceeding with the following repair procedure, review all warnings and cautions. (Refer to 23 - BODY/SEATS - WARNING)
2. Using a trim stick C-4755 or equivalent, separate the seven front console bezel clips (2), lift up the back of the bezel (1) and remove.
3. Remove the bolts (1) and lift the rear of the base up to release the front guide pins (5).
4. Remove the front base (2).
NOTE: Do not reuse the seat fasteners, always replace with new ones.
5. Remove and discard the front bolts (4).
6. Position the seats forward, remove the rear bolts (2) and discard.
7. Disconnect the 12v power supply electrical connector (3 - if equipped).
8. Fold the seat backs forward and roll the seat assembly (1) back in the vehicle.
9. Remove the nuts (2) attaching the center seat console (1) to the drivers seat and the passenger seat and discard.
10. Remove the nuts (4) attaching the center console (2) to the drivers seat (3) and the passenger seat in the rear of the seat and discard.
11. Disconnect the electrical connector (1 - if equipped).
12. Roll the seat assembly forward and remove the center seat console.
Old Mar 7, 2008 | 07:44 PM
vzdude's Avatar
DTR's 'Go to Guy'
REMOVAL
1. If equipped, remove the floor console, (Refer to 23 - BODY/INTERIOR/FLOOR CONSOLE - REMOVAL) .
2. Remove the bezel (2).
3. Remove the screws (2) and remove the cup holder (1).
Old Mar 7, 2008 | 07:45 PM
vzdude's Avatar
DTR's 'Go to Guy'
Dang!......if you need pictures.....let me know!
Old Mar 7, 2008 | 07:52 PM
Raspy's Avatar
vz,
Sheesh! Thanks! Sorry for all the trouble. I gotta go get a trim stick.
John
wardy70
May 9, 2009 03:07 PM
CTD2001
Dec 3, 2006 07:18 PM
rico334
14
Jan 10, 2006 07:25 PM
RamRat
Jul 22, 2005 08:04 AM
Mechanos
Mar 30, 2005 01:04 PM
