quad cabs with sunroof i have a question
hey guys just have a question im lookin into painting my truck over and do a few other things to it probly next year gotta put some money together and a few other things anyways to the point i have no sunroof right now thinking of putting one in all factory parts do you guys have an overhead counsole with your sunroofs or no?
my trucks an 05 so you guys know.
thanks guys
thanks guys
I've got the sunroof in my '05 quad cab. Yes, the console is there. The sunroof switch mounts between the driver and passenger courtesy lights. You'll need the headliner, maybe the console, styrofoam insulation, etc, and all the bits for the sunroof itself. I have no idea if the wiring is there with the harness. There's probably a drain that works its way down under the truck.
The challenge will be the hole in the roof. The sunroof glass has rounded corners and it rises up into and through the roof during its travels. (It slides back between the headliner and the roof, or the rear tilts upward). The factory hole in the roof has rolled edges for a good bit of the penetration including the corners. The sunroof glass is a close fit to the hole. There may be some mounting bosses you'd need to fabricate and braze to the roof's underside. I've not had the headliner out, fortunately.
Good luck. I'd go take a close look at the doner truck before cutting into the roof. You may choose to swap out the cab for one with the hole instead.
yea if i do end up installing a sunroof i'll put a hole new roof skin on cut the old one out weld the new onne in the whole 9 yards i know what its gonna consist of my father owns an auto body shop and i'v been workin there since i can remember so even parts i'll be able to get at his cost witch will be nice i ruffly priced it out on line (not my prices) and for the roof skin headliner sunroof modual drain tubes and wireing harnes lookin around 1300.00 and all the labor i'll do myself.
kerry.king
60
03-24-2013 10:23 AM
gts95
05-08-2009 11:30 PM
hold23
12-10-2007 12:04 PM
