Power Windows - All Auto Switches?
Does anyone know if the power window switches in my 2005 Ram can be swapped out with any other Dodge model that has auto up / auto down on all four switches?
It currently does auto down on the drivers window only. You have to hold the button for "up" and you have to hold the button for "up" and "down" for all the other windows (as I recall...)
I have a Lexus GS400 for a car, and it's just sooo convenient on a hot day to click all four switches back and roll down all windows simultaneously without having to hold them. (and vice-versa to put them up.)
It'd be even better to have a single "all open / all closed" button - which I suppose could be fabbed up with a little work...
Anyway, I just wondered if another vehicle shared the same switch panel, but provided the auto switches. Then I could just swap it out.
It's a silly little differentiator that the auto makers are using to give you more features when you buy the more expensive, or "more luxury" car - yet it's about $0.10 worth of switches...
For example, when I bought my car, the Lexus ES300 ($35,000) had a single auto switch and the GS400 ($45,000) had all four.
hmm - I couldn't find anything directly related on their site, and I'm not sure how it would work - but I e-mailed Autoloc to ask them about it, to see if they have a solution.
Maybe they can come up with the all up / all down switch...
I'll let you know the result if they reply.
ONE TOUCH UP AND DOWN WINDOW UNIT
Estimate install time 45 MIN.
AUTOLOC POWER ACCESSORIES
Add the convenience of one touch windows to any vehicle. Fully compatible with any domestic, import, or after-market power window system. Simply tap the switch once and the window with travel all the way up or down.
There's never any need to mount additional switches because AutoLoc's WC1000 works with all factory window switches! The WC1000 may be used with any factory or aftermarket remote control devices to operate your windows by remote, including alarms, and keyless entry unit!
Each system include detailed instructions insuring easy installation even for the weekend mechanic!
When Quality Counts, Count on AutoLoc!
Compatible With Any Window System or sunroof
Works Off Factory Window Switches
Load Sensor
Auto Stop
May Be Used With Any Remote
Works With Alarms!
Microprocessor Controlled
Detailed Instructions
Limited Lifetime Warranty,each module will either close 2 windows OR open and close 1 window
Load Sensor
Auto Stop
Works With Alarms!
The autoloc.com website is very hard to navigate. I THINK this is what you guy's are wanting. I'm trying to call autothisworld.com to see how it would work with all 4 window's. I'll keep you posted on what I find out.
http://www.autothisworld.com/search.lasso?search=wc1000
Originally Posted by reecegr
autoloc.com type wc1000 in search box 39.00 never found them cheaper except fleabay once in a while
So does this make it where all windows will go down. Or do you have to have one for each window. Then, will that work from the driver's door.
Fyi, i think most auto mfgs don't do the auto up thing because kids, and stupid people put their arms and heads in the window and ouch, or worse.
The ones that do have the auto up, like maybe your lexus, probably has some safety feature in there that stops the window if there is something in it that gives resistance. Put your head, I mean broom stick in there and give it a try.
Yeah, the Lexus does have a pinch-proof feature on windows that will go back if they meet resistance. I assumed all vehicles had that feature now, even if they aren't express up/down.
Hold on, I'll go stick my head in my Ram window and check it out...
sootnsmoke
19
Oct 12, 2012 11:28 PM
Rednecktastic
Nov 15, 2010 09:29 PM
markster
Oct 7, 2006 02:20 PM
