power windows
Old Feb 1, 2010 | 08:35 PM
gunnie's Avatar
power windows
hey guys
The power windows in my 06 all quit working at the same time, tried the window lock too many times to count, pulled the switch and no power coming into the window switch, the door locks and the mirrors work fine and I have the red wire to ground with a test light that shows power to the door locks. Would it just be easier to run a new hot wire to the window switch? Could I tie into the power wire for the door locks? What color wire powers the window switch from the TIPM? Or is there a fuse somewhere that I am unable to locate? I've read about a 3 way splice somewhere down around the e-brake pedal, but don't know for sure where. Any suggestions would be appreciated
thanks gunnie
Old Feb 2, 2010 | 08:19 PM
gunnie's Avatar
I have a little more info, I put a volt meter on it and have 14.2 on the pink/yellow stripe wire on either black ground. I get 7.8 on one of the wires on the end connector. Can anyone help me out I am struggling a bit more than usual with this?
Old Feb 4, 2010 | 12:12 PM
davidj54's Avatar
There have been several people that have found a broken or partially broken wires in the boot where the wiring goes through the door.
You can find Wiring daigrams at http://www.dodge.com/bodybuilder/year.pdf
The Pink/Yellow feed power to all the switches. My bet is that you have a bad connection at the connector.
Old Mar 17, 2010 | 08:59 AM
flatbed beast's Avatar
Does Anyone know where the power window circuit breaker is?
Rednecktastic
Nov 15, 2010 09:29 PM
04ctd
Dec 23, 2006 08:23 PM
markster
Oct 7, 2006 02:20 PM
pmtg
Dec 16, 2004 03:46 PM
coyote22250
Aug 26, 2003 12:46 PM
